Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Engineering Vibration Analysis: Worked Problems
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2618
09-03-2014, 05:21 PM (This post was last modified: 09-03-2014, 06:20 PM by usman.)
Engineering Vibration Analysis: Worked Problems 1
Author: Valery A. Svetlitsky | Size: 6 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 1 edition (March 5, 2004) | pages: 319 | ISBN: B000PY4HGE
[Image: 88479425196092617470.jpg]
The two-volume work "Engineering Vibration Analysis" is devoted to problems on vibration theory analysis, which is currently one of the fundamental courses in mechanical engineering departments at technical universities.
The first volume is devoted to systems with a finite number of degrees of freedom and continuous systems are analyzed in the second. In the first part of each volume problems are posed and in the second part the detailed solutions to these problems are dealt with. Conventional and advanced problems requiring deeper knowledge of the vibration theory are analyzed. In particular, problems are formulated associated with the determination of frequencies and vibration modes, the study of free and forced vibrations, as well as with parametric and nonlinear vibration analysis. The problems associated with determination of critical parameters, dynamic stability and with random vibrations are also considered. The algorithms for their solutions are presented with probability characteristics calculation, and a reliability estimation (probability of non-failure operation) of the corresponding mechanical system.
[-] The following 15 users Like amindoxiti's post:15 users Like amindoxiti's post
  • vardan, gulilero, zrilek, bridgeengineer, Mohammad6299, warlord1, ssobhan, Dell_Brett, malc, dinu69in, TAFATNEB, PinkPant, toa011, ykhackhack, kowheng
 amindoxiti
User ID: 86739
Threads: 203
Given Likes: 2618
09-03-2014, 05:31 PM
Engineering Vibration Analysis: Worked Problems 2
Author: Valery A. Svetlitsky | Size: 5 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2004 edition (February 23, 2004) | pages: 239 | ISBN: 3540207821
[Image: 39032671609947928370.jpg]
Constantly increasing attention is paid in the course 'Vibration 'Theory' to vibration of mechanical systems with distributed parameters, since the real elements of machines, devices, and constructions are made of materials that are not perfectly rigid. 'Therefore, vibrations of the objects including, for ex­ ample, rod elastic elements excite the vibrations of these elements, which can produce a substantial effect on dynamic characteristics of moving objects and on readings of instruments. For a mechanical engineer working in the field of design of new technolo­ gies the principal thing is his know-how in developing the sophisticated math­ ematical models in which all specific features of operation of the objects under design in real conditions are meticulously taken into account. So, the main emphasis in this book is made on the methods of derivation of equations and on the algorithms of solving them (exactly or approximately) taking into con­ sideration all features of actual behavior of the forces acting upon elastic rod elements. 'The eigen value and eigen vector problems are considered at vibrations of curvilinear rods (including the rods with concentrated masses). Also consid­ ered are the problems with forced vibrations. When investigating into these problems an approximate method of numerical solution of the systems of lin­ ear differential equations in partial derivatives is described, which uses the principle of virtual displacements. Some problems are more complicated than others and can be used for practical works of students and their graduation theses.
[-] The following 21 users Like amindoxiti's post:21 users Like amindoxiti's post
  • vardan, gulilero, bridgeengineer, zrilek, Mohammad6299, warlord1, ssobhan, Dell_Brett, malc, dinu69in, subin91, TAFATNEB, blaze, PinkPant, toa011, ykhackhack, slowet, Quantumm, draluka, cristi, kowheng
  Vibration Problems ICOVP 2007: Eighth International Conference, 01-03 February 2007, TAFATNEB 0 2,620 04-27-2023, 08:52 AM
  Advances in Vibration Engineering and Structural Dynamics ssobhan 3 3,287 05-07-2019, 03:28 AM
  Noise and Vibration Analysis: Signal Analysis and Experimental Procedures jamildear4u 4 3,257 04-17-2019, 12:51 AM
  Vibration and Structural Acoustics Analysis: Current Research and Related Technologie Dell_Brett 2 2,664 04-16-2019, 01:01 AM
  Intelligent Vibration Control in Civil Engineering Structures amindoxiti 0 1,747 08-11-2017, 11:49 AM
  Mechanical Vibration and Shock Analysis, 2nd edition (5 - volumes) TAFATNEB 4 2,652 12-12-2016, 11:36 PM
Last Post: gulilero
  Vibration Theory and Applications with Finite Elements and Active Vibration Control bridgeengineer 0 1,507 04-18-2016, 06:33 AM
Last Post: bridgeengineer
