Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Mechanical Vibration and Shock Analysis, 2nd edition (5 - volumes)
12-12-2016, 11:10 AM (This post was last modified: 12-12-2016, 11:15 AM by TAFATNEB. Edit Reason: N/A )
Mechanical Vibration and Shock Analysis, 2nd edition - Mechanical Shock. Volume 2
Author(s)/Editor(s): Christian Lalanne | Size: 7.47 MB | Format: PDF | Quality: Unspecified | Publisher: WILLY | Year: 2009 | pages: 416 | ISBN: 1848211236
[Image: 13012836987808756753.jpg]
Mechanical Vibration and Shock Analysis, Second Edition
Volume 2: Mechanical Shock
This volume considers the shock response spectrum, its various definitions, its properties, and the assumptions involved in its calculation. In developing the practical application of these concepts, the shock shapes or profiles most often used in test facilities are presented, together with their characteristics and indications of how to establish test configurations comparable with those of the real-world, measured environment. Following this analysis there is a case study of how to meet these specifications using standard laboratory equipment, shock machines, electrodynamic exciters driven by a time signal or a response spectrum. Discussion of the limitations, advantages and disadvantages of each method is presented.
The Mechanical Vibration and Shock Analysis five-volume series has been written with both the professional engineer and the academic in mind. Christian Lalanne explores every aspect of vibration and shock, two fundamental and extremely significant areas of mechanical engineering, from both a theoretical and practical point of view. The five volumes cover all the necessary issues in this area of mechanical engineering. The theoretical analyses are placed in the context of both the real world and the laboratory, which is essential for the development of specifications.
Mechanical Vibration and Shock Analysis, Sinusoidal Vibration (Volume 1)
Author(s)/Editor(s): Christian Lalanne | Size: 5 MB | Format: PDF | Quality: Unspecified | Publisher: WILLY | Year: 2009 | pages: 405 | ISBN: 1848211228
[Image: 02255022760673993902.jpeg]
Mechanical Vibration and Shock Analysis, Second Edition Volume 1: Sinusoidal Vibration The relative and absolute response of a mechanical system with a single degree of freedom is considered for arbitrary excitation, and its transfer function defined in various forms.
The characteristics of sinusoidal vibration are examined in the context both of the real world and of laboratory tests, and for both transient and steady state response of the single–degree–of–freedom system. Viscous damping and then nonlinear damping are considered. The various types of swept sine perturbations and their properties are described and, for the one–degree–of–freedom system, the consequence of an inappropriate choice of sweep rate are considered. From the latter, rules governing the choice of suitable sweep rates are developed. The Mechanical Vibration and Shock Analysis five–volume series has been written with both the professional engineer and the academic in mind. Christian Lalanne explores every aspect of vibration and shock, two fundamental and extremely significant areas of mechanical engineering, from both a theoretical and practical point of view. The five volumes cover all the necessary issues in this area of mechanical engineering. The theoretical analyses are placed in the context of both the real world and the laboratory, which is essential for the development of specifications.
  • zrilek, oanm2000, apocalipse, K.Lee, Dell_Brett, Aviator
12-12-2016, 11:19 AM
Mechanical Vibration and Shock Analysis, Fatigue Damage (Volume 4)
Author(s)/Editor(s): Christian Lalanne | Size: 7 MB | Format: PDF | Quality: Unspecified | Publisher: WILLY | Year: 2009 | pages: 448 | ISBN: 1848211252
[Image: 64882448056693746289.jpeg]
Mechanical Vibration and Shock Analysis, Second Edition Volume 4: Fatigue Damage Fatigue damage in a system with one degree of freedom is one of the two criteria applied when comparing the severity of vibratory environments.
The same criterion is also employed for a specification representing the effects produced by the set of vibrations imposed in a real–world environment. In this volume, which is devoted to the calculation of fatigue damage, the author explores the various hypotheses and models used to describe the behavior of material suffering fatigue and the laws of fatigue accumulation. He also considers the methods of counting response peaks, which are used to establish a histogram when it is impossible to use the probability density of the peaks obtained with a Gaussian signal.
The expressions for mean damage and its standard deviation are established and other hypotheses are tested. The Mechanical Vibration and Shock Analysis five–volume series has been written with both the professional engineer and the academic in mind. Christian Lalanne explores every aspect of vibration and shock, two fundamental and extremely significant areas of mechanical engineering, from both a theoretical and practical point of view. The five volumes cover all the necessary issues in this area of mechanical engineering. The theoretical analyses are placed in the context of both the real world and the laboratory, which is essential for the development of specifications.
  • oanm2000, zrilek, apocalipse, K.Lee, Dell_Brett, Aviator
12-12-2016, 11:24 AM
Mechanical Vibration and Shock Analysis, Specification Development (Volume 5)
Author(s)/Editor(s): Christian Lalanne | Size: 9.5 MB | Format: PDF | Quality: Unspecified | Publisher: WILLY | Year: 2009 | pages: 460 | ISBN: 1848211260
[Image: 58668819424057034532.jpeg]
Mechanical Vibration and Shock Analysis, Second Edition Volume 5: Specification Development This volume focuses on specification development in accordance with the principle of tailoring. Extreme response and the fatigue damage spectra are defined for each type of stress (sinusoidal vibration, swept sine, shock, random vibration, etc.).
The process for establishing a specification from the life cycle profile of the equipment which will be subject to these types of stresses is then detailed. The analysis takes account of the uncertainty factor, designed to cover uncertainties related to the real–world environment and mechanical strength, and the test factor, which takes account of the number of tests performed to demonstrate the resistance of the equipment. The Mechanical Vibration and Shock Analysis five–volume series has been written with both the professional engineer and the academic in mind. Christian Lalanne explores every aspect of vibration and shock, two fundamental and extremely significant areas of mechanical engineering, from both a theoretical and practical point of view. The five volumes cover all the necessary issues in this area of mechanical engineering. The theoretical analyses are placed in the context of both the real world and the laboratory, which is essential for the development of specifications.
  • zrilek, oanm2000, K.Lee, Dell_Brett, Aviator
12-12-2016, 11:29 AM
Mechanical Vibration and Shock Analysis: Volume 3: Random Vibration (3rd Edition)
Author(s)/Editor(s): Christian Lalanne | Size: 13 MB | Format: PDF | Quality: Unspecified | Publisher: WILLY | Year: 2014 | pages: 648 | ISBN: 1848216467
[Image: 68147875922633870454.jpeg]
The vast majority of vibrations encountered in the real environmentare random in nature. Such vibrations are intrinsically complicatedand this volume describes the process that enables us to simplifythe required analysis, along with the analysis of the signal in thefrequency domain.
The power spectrum density is also defined, together with therequisite precautions to be taken in its calculations as well asthe processes (windowing, overlapping) necessary to obtain improvedresults.
An additional complementary method the analysis ofstatistical properties of the time signal is alsodescribed. This enables the distribution law of the maxima of arandom Gaussian signal to be determined and simplifies thecalculation of fatigue damage by avoiding direct peak counting.
  • zrilek, oanm2000, apocalipse, Dell_Brett, Aviator
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
12-12-2016, 11:36 PM
[-] The following 10 users Like gulilero's post:10 users Like gulilero's post
  • malc, zrilek, oanm2000, TAFATNEB, bridgeengineer, cace-01, Dell_Brett, Aviator, ajmf77, kowheng
  Noise and Vibration Analysis: Signal Analysis and Experimental Procedures jamildear4u 4 3,261 04-17-2019, 12:51 AM
  Vibration and Structural Acoustics Analysis: Current Research and Related Technologie Dell_Brett 2 2,671 04-16-2019, 01:01 AM
  Mechanical Vibrations: Theory and Application to Structural Dynamics; Third Edition amindoxiti 3 2,850 04-15-2019, 06:54 AM
  Flow-Induced Vibration 2nd edition sabooryan 0 1,560 01-07-2018, 05:41 PM
Last Post: sabooryan
  Vibration Theory and Applications with Finite Elements and Active Vibration Control bridgeengineer 0 1,511 04-18-2016, 06:33 AM
Last Post: bridgeengineer
  Vibration Analysis and Structural Dynamics for Civil Engineers cace-01 2 2,339 03-23-2016, 11:13 PM
  Random Vibrations: Analysis of Structural and Mechanical Systems Grunf 5 3,710 12-17-2014, 12:45 PM
