Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Drift Demand and Capacity of Non-seismically Designed Concrete Buildings in H
04-26-2014, 05:09 PM
Seismic Drift Demand and Capacity of Non-seismically Designed Concrete Buildings in Hong Kong
Author: R.K.L. Su;N.T.K. Lam;H.H. Tsang | Size: 262 KB | Format: PDF | Quality: Unspecified | Publisher: EJSE Special Issue: Earthquake Engineering in the low and moderate seismic regions of Southeast Asia and Australia (2008) | Year: 2008 | pages: 12
[Image: 62033955197118754910.jpg]
ABSTRACT: This paper reviews the seismic engineering research conducted in Hong Kong with special
emphasis on the prediction of the seismic drift demand and capacity of existing buildings which have not been
designed and detailed to address potential seismic hazards. The paper begins with a comprehensive summary
of the local construction and detailing practice of concrete structures, followed by a summary of the drift ratio
capacity, ductility capacity, stiffness variation and non-linear damping properties of the non-seismically designed
reinforced concrete components. Seismic design response spectra for rock sites developed from Chinese
Code GB50011-2001 are compared with the uniform hazard response spectra developed at the University
of Hong Kong. The over-conservatism of the Chinese Code particularly in the long period range (T > 2 sec)
is highlighted. A direct displacement based method used for the prediction of the maximum drift demands of
existing buildings in Hong Kong is also introduced. Phenomena such as stiffness degradation, period shifting,
non-linear damping and higher mode effects have been incorporated into the modelling. Lastly, the predicted
maximum inter-storey drift demand of 0.3% is compared with the minimum ultimate drift capacity of approximately
1.5%. The capacity predictions were based on results from experimental cyclic load testings of
concrete sub-assemblages undertaken in Hong Kong in recent times. The potential risk of damage in Hong
Kong buildings under seismic attacks is discussed.
  • rezart, vardan, malc, zrilek, ruaumoko
  Enhancing the Capacity of Concrete Bridges ir_71 2 7,329 02-14-2018, 10:58 PM
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 4,895 03-16-2016, 09:41 AM
  EXPERIMENTAL MULTI-LEVEL SEISMIC PERFORMANCE ASSESSMENT OF 3D RC FRAME DESIGNED FOR D TAFATNEB 0 4,071 06-03-2014, 09:01 PM
  Some Remarks on the Seismic Demand Estimation in the Context of Vulnerability Assessm TAFATNEB 0 3,862 05-10-2014, 10:21 AM
  Control of Seismic Drift Demand for Reinforced Concrete Buildings with Weak First Sto TAFATNEB 0 4,094 04-26-2014, 05:17 PM
  VULNERABILITY TO PROGRESSIVE COLLAPSE OF SEISMICALLY DESIGNED RC FRAMED STRUCTURES: C TAFATNEB 0 4,317 04-26-2014, 10:22 AM
  Seismic performance of a 12-storey ductile concrete shear wall system designed accord TAFATNEB 0 4,465 04-21-2014, 10:41 PM
