Civil Engineering Association eBooks Journals, Papers and Presentations Performance-Based Seismic Retrofit Strategy for Existing Reinforced Concrete Frame Sy
04-03-2014, 12:41 PM
Performance-Based Seismic Retrofit Strategy for Existing Reinforced Concrete Frame Systems Using Fiber-Reinforced Polymer Composites
Author: Stefano Pampanin ; Davide Bolognini ; and Alberto Pavese | Size: 2.2 MB | Format: PDF | Quality: Unspecified | Publisher: Univ. of Canterbury, Christchurch, New Zealand. | Year: 2007 | pages: 16
[Image: 54903711119079357969.png]
The feasibility and efficiency of a seismic retrofit intervention using externally bonded fiber-reinforced polymer composites on
existing reinforced concrete frame systems, designed prior to the introduction of modern standard seismic design code provisions in the mid-1970s, are herein presented, based on analytical and experimental investigations on beam-column joint subassemblies and frame systems. A multilevel retrofit strategy, following hierarchy of strength considerations, is adopted to achieve the desired performance. The expected sequence of events is visualized through capacity-demand curves within M-N performance domains. An analytical procedure
able to predict the enhanced nonlinear behavior of the panel zone region, due to the application of CFRP laminates, in terms of shear strength .principal stresses. versus shear deformation, has been developed and is herein proposed as a fundamental step for the definition of a proper retrofit solution. The experimental results from quasistatic tests on beam-column subassemblies, either interior and exterior, and on three-storey three-bay frame systems in their as-built and CFRP retrofitted configurations, provided very satisfactory confirmation
of the viability and reliability of the adopted retrofit solution as well as of the proposed analytical procedure to predict the actual sequence
of events.
  • zrilek, malc, ruaumoko, civilgen
  Cause of Cracking in Post-Tensioned Concrete Box Girder Bridges and Retrofit Proced. Aviator 2 7,834 11-18-2020, 04:13 AM
Last Post: tomtumx
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,330 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,133 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 8,766 02-10-2016, 02:49 PM
  2nd ATC-SEI Conference on Improving the Seismic Performance of Existing Buildings and RyanRS 0 5,223 10-29-2015, 12:55 AM
Last Post: RyanRS
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 5,899 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 7,032 07-08-2015, 08:02 AM
Last Post: PinkPant
