Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 28842 Guidelines for simplified design of reinforced concrete bridges
11-26-2013, 08:05 PM
ISO/DIS 28842:2010 Guidelines for simplified design of small reinforced concrete bridges
Author: ISO/TC 71 | Size: 6.54 MB | Format: PDF | Quality: Original preprint | Publisher: ISO | Year: 2010 | pages: 197
[Image: 09757277875591231367.jpg]
This document can be permitted to be used as an alternative to the development of a National Concrete Bridge Design and Construction Code, or equivalent document in countries where no national design codes are available by themselves, or as an alternative to the National Concrete Bridge Design and Construction Code in countries where specifically considered and accepted by the national standard body or other appropriate regulatory organization, and applies to the planning, design and construction of structural concrete bridges to be used in new bridges of restricted span length, height of piers, and type.
The purpose of these guidelines is to provide a registered Civil Engineer with sufficient information to perform the design of the structural concrete bridge that complies with the limitations established in 6.1. The rules of design as set forth in the present document are simplifications of more elaborate requirements.
Although the guidelines contained in this document were drawn to produce, when properly employed, a structural concrete structure with an appropriate margin of safety, these guidelines are not a replacement of sound and experienced engineering. In order for the resulting structure designed employing these guidelines to attain the intended margin of safety. The document must be used as a whole and alternative procedures should be employed only when explicitly permitted by the guidelines. The minimum dimensioning guides as prescribed in the document replace, in most cases, more elaborate procedures as those prescribed in the National Code, and the eventual economic impact is compensated by the simplicity of the procedures prescribed here.
The professional performing the structural design under these guidelines should meet the legal requirements for structural designers in the country of adoption and have training and a minimum appropriate knowledge of structural mechanics, statics, strength of materials, structural analysis, and reinforced concrete design and construction.
Designs and details for new bridges should address structural integrity by considering the following:
The use of continuity and redundancy to provide one or more alternate paths.
Structural members and bearing seat widths that are resistant to damage or instability.
External protection systems to minimize the effects of reasonably conceived severe loads
  • Dell_Brett, malc, tang1942, hatkam, andersen3, st77bel, blaze, pezhmankhan, fred2010, Hengki, peixoto, zrilek, RyanRS, K.Lee
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
05-23-2016, 07:56 AM
new links
password:
direct link
[-] The following 15 users Like andersen3's post:15 users Like andersen3's post
  • gafi, slowet, RyanRS, Hengki, f_slikken, Jackass, bridgeengineer, malc, Dell_Brett, jfjdm, K.Lee, PinkPant, ruaumoko, pram, kristoffer_89
01-28-2024, 12:56 PM
ISO 28842:2013 Guidelines for simplified design of reinforced concrete bridges
| Size: 17.14 MB| Format: PDF| Quality: Scanner| Year: 2013
[Image: 16011893005779653082.jpg]
The purpose of ISO 28842:2013 is to provide sufficient information to perform the design of the structural concrete bridge that complies with the limitations established in ISO 28842:2013. The rules of design as set forth in ISO 28842:2013 are simplifications of more elaborate requirements.
ISO 28842:2013 can be used as an alternative to the development of a national concrete bridge design and construction code, or equivalent document in countries where no national design codes are available by themselves, or as an alternative to the national concrete bridge design and construction code in countries where specifically considered and accepted by the national standards body or other appropriate regulatory organization, and applies to the planning, design and construction of structural concrete bridges to be used in new bridges of restricted span length, height of piers, and type.
  • subin91, babakfeyzi, PinkPant, malc, kowheng
  ISO 21725-2: Simplified design of prestressed concrete bridges Part 2: Box-girder bri poolmand 2 4,018 01-29-2024, 05:37 AM
  ISO 28841 Guidelines for simplified seismic assessment and rehabilitation of concrete ir_71 3 4,654 01-28-2024, 12:51 PM
  ISO 22502 Simplified design of connections of concrete claddings to concrete structur poolmand 0 2,770 01-28-2024, 12:48 PM
  ISO 20987 Simplified design for mechanical connections between precast concrete struc poolmand 0 2,790 01-28-2024, 12:45 PM
  ISO 21725-1: Simplified design of prestressed concrete bridges Part 1: I-girder bridg poolmand 0 2,804 01-27-2024, 07:21 AM
