Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 28841 Guidelines for simplified seismic assessment and rehabilitation of concrete
11-26-2013, 07:56 PM
ISO/DIS 28841:2010 Guidelines for simplified seismic assessment and rehabilitation of concrete buildings
Author: ISO/TC 71 | Size: 3.37 MB | Format: PDF | Quality: Original preprint | Publisher: ISO | Year: 2010 | pages: 80
[Image: 22574974751727280248.jpg]
This document can be permitted to be used as an alternative to the development of a building code, or equivalent document in countries where no national design codes are available by themselves, or as an alternative to the building code in countries where specifically considered and accepted by the national standards body or other appropriate regulatory organization, and applies to the assessment of earthquake resistance capability and to the seismic rehabilitation design and construction for existing structural concrete buildings.
The purpose of these guidelines is to provide a registered civil engineer with sufficient information to perform the seismic assessment and rehabilitation of the structural concrete building that complies with the limitations established in 5., for both undamaged structures that are deemed not to comply with the required characteristics for an adequate response at a specified performance level, and for structures that have undergone damages under seismic loadings. The rules of design as set forth in the present document are simplifications of more elaborate requirements.
Although the guidelines contained in this document were drawn to produce, when properly employed, a reasonable assessment of the seismic vulnerability of an undamaged structure, a reasonable assessment of a structure damaged by a seismic event and a structural rehabilitation of the assessed concrete structure with an appropriate margin of safety, these guidelines are not a replacement of sound and experienced engineering. In order to attain the intended results on assessment and rehabilitation design, the document must be used as a whole, and alternative procedures should be employed only when explicitly permitted by the guidelines. The minimum dimensioning guides as prescribed in the document replace, in most cases, more elaborate procedures as those prescribed in the national code or, if no national code exists, in internationally recognized full fledged codes, and the eventual economic impact is compensated by the simplicity of the procedures prescribed here.
The professional applying the procedures set forth by these guidelines should meet the legal requirements for structural designers in the country of adoption and have training and a minimum appropriate knowledge of structural mechanics, statics, strength of materials, structural analysis, and reinforced concrete design and construction.
While buildings rehabilitated in accordance with these guidelines are expected to perform within the selected performance levels for the applicable design earthquakes, compliance with this guidelines are necessary but may not guarantee the sought for performance, as current knowledge of structural behavior under seismic loads, and of the loads themselves, is yet incomplete.
  • jcbv, Dell_Brett, oanm2000, malc, andersen3, st77bel, blaze, pezhmankhan, Hengki, peixoto, zrilek, pram
07-19-2014, 07:16 AM
Direct link:
I.R.
  • malc, jcbv, ruaumoko, vardan, Mohammad6299, Jackass, sodapas, ibg0203, aslam, Dell_Brett, Hengki
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
01-08-2015, 05:48 PM
new link
password:
  • jcbv, Dell_Brett, PinkPant, bridgeengineer, pram
01-28-2024, 12:51 PM
ISO 28841:2013 Guidelines for simplified seismic assessment and rehabilitation of concrete buildings
| Size: 5.42 MB| Format: PDF| Quality: Scanner| Year: 2013-06
[Image: 75589386071161384478.jpg]
The purpose of ISO 28841:2013 is to provide sufficient information to perform the seismic assessment and rehabilitation of the structural concrete building that complies with the limitations established in ISO 28841:2013, for both undamaged structures that are deemed not to comply with the required characteristics for an adequate response at a specified performance level, and for structures that have undergone damage under seismic loadings. The rules of design as set forth in ISO 28841:2013 are simplifications of more elaborate requirements.
ISO 28841:2013 can be used as an alternative to the development of a building code, or equivalent document in countries where no national design codes are available by themselves, or as an alternative to the building code in countries where specifically considered and accepted by the national standards body or other appropriate regulatory organization, and applies to the assessment of earthquake resistance capability and to the seismic rehabilitation design and construction for existing structural concrete buildings.
  • subin91, babakfeyzi, PinkPant, malc, kowheng
  ISO 21725-2: Simplified design of prestressed concrete bridges Part 2: Box-girder bri poolmand 2 4,005 01-29-2024, 05:37 AM
  ISO 28842 Guidelines for simplified design of reinforced concrete bridges ir_71 2 4,176 01-28-2024, 12:56 PM
  ISO 22502 Simplified design of connections of concrete claddings to concrete structur poolmand 0 2,762 01-28-2024, 12:48 PM
  ISO 20987 Simplified design for mechanical connections between precast concrete struc poolmand 0 2,782 01-28-2024, 12:45 PM
  ISO 21725-1: Simplified design of prestressed concrete bridges Part 1: I-girder bridg poolmand 0 2,802 01-27-2024, 07:21 AM
