Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 314: Guide to Simplified Design for Reinforced Concrete Buildings
 hamex
User ID: 27162
Threads: 1
Likes: 49 in 1 posts
Given Likes: 43
09-24-2013, 08:13 AM (This post was last modified: 05-03-2023, 08:48 AM by Administrator.)
ACI 314R-11: Guide to Simplified Design for Reinforced Concrete Buildings
PDF File format - 138 pages
[Image: 32950566530224352344.jpg]
[-] The following 49 users Like hamex's post:49 users Like hamex's post
  • malc, viet2010, cace-01, araza023, ronnie_150, rezart, Jackass, nhim4mat2006, RyanRS, isurya, Diquan, techno, brandizzo, Rapaig, rendel_©, pontiac, subin91, chenamoy, vvvv, spiderthan, StaadEng, ivanveliki, usman, nickycruz, rcnet, ykhackhack, eliseo.as, gulilero, cosminupt, Mohammad6299, ruaumoko, zego2000, salahcivil, bigone, ting tsai huang, ssobhan, carolinandra, chairatpk, miquan, zrilek, amiboyz, tattiya, igor1234, harsono, sacem, chrono146, chicosi, GMianG, pedzaquino
 Rapaig
User ID: 20672
Threads: 7
Likes: 119 in 16 posts
Given Likes: 160
09-24-2013, 12:27 PM (This post was last modified: 04-29-2015, 04:04 AM by mybest.)
[-] The following 22 users Like Rapaig's post:22 users Like Rapaig's post
  • st77bel, pontiac, odiclas, vardan, hatkam, f_slikken, ivanveliki, oanm2000, ykhackhack, Albert, Dell_Brett, jfjdm, Hengki, ali akbar, knrsa, Mohammad6299, simanta, hamex, lisine, mgdario, bigone, malc
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
12-10-2013, 09:32 AM
[-] The following 9 users Like bigone's post:9 users Like bigone's post
  • lednar_ved, Dell_Brett, Veggeta, simanta, ali akbar, Munykong, ralarcon, jayborre, milova
Likes: 8,200 in 1,338 posts
05-03-2023, 08:27 AM
ACI PRC-314-16 Guide to Simplified Design for Reinforced Concrete Buildings
Author(s)/Editor(s): ACI Committee 314 | Size: 9.13 MB| Format: PDF| Quality: Original preprint| Year: 2016| pages: 128 | ISBN: 9781942727934
[Image: 24726329438171540138.png]
This guide presents simplified methods and design techniques that facilitate and speed the engineering of low-rise buildings within certain limitations. Material is presented in an order that follows typical design process with procedures introduced as the designer will need them in the course of a building design. Much of the information presented in this guide is derived from ACI 318, ASCE 7, and the 2015 International Building Code (IBC) (International Code Council 2015). The quality and testing of materials used in construction are covered by references to the appropriate ASTM standard specifications.
Whereas many of the tables, charts, and values included in this guide originated from the aforementioned reference documents, they have been modified or reorganized to be more conservative, to match design process flow, or better support the holistic and simplified design approach presented.
Although this guide is not written in mandatory language, the information is presented in such a manner that a structure designed following this guide will, in principle, comply with the codes and standards on which it was based. Although this guide is written in nonmandatory language, it is meant to be applied as a whole, because the simplified provisions are interdependent, and it would be unsafe to employ only a portion of this guide and disregard the remainder. This guide is not a code and is not deemed to satisfy ACI 318, ASCE 7, and the International Building Code (International Code Council 2015). This guide is expected to be especially useful in the education and training of engineers in reinforced concrete design of low-rise structures of small to medium floor areas.
There are many options within these standards that are not considered in this guide, such as the use of supplementary cementitious materials in concrete mixtures. As this guide will be used as a design aid, it is the licensed design professional’s responsibility to ensure that the structure design satisfies the requirements of ACI 318, ASCE 7, the International Building Code (International Code Council 2015), and the legal requirements of the local jurisdiction. The original draft of the guide, published as ACI IPS-1 (2002), was produced by a Joint Committee of Instituto Colombiano de Normas Técnicas y Certificación (Colombian Institute for Technical Standards and Certification) (ICONTEC) and Asociación Colombiana de Ingeniería Sísmica (Colombian Association for Earthquake Engineering) (AIS).
The initial drafting of ACI IPS-1 (2002) was motivated by frequent worldwide discussions that reinforced concrete codes might be unnecessarily sophisticated for some applications, such as small low-rise buildings. Current knowledge of reinforced concrete behavior obtained through experimentation and experience, and its status and dissemination as a structural material used worldwide, made developing a simplified design and construction guide feasible. This guide used ACI IPS-1 (2002) as a basis, with information derived from ACI 318, ASCE 7, and the International Building Code (International Code Council 2015).
This guide presents simplified approaches to assist engineers in designing low-rise buildings within certain limitations, in addition to the following:
(a) Information on the order needed in the course of a design
(b) Explanatory material at appropriate places
© Computations only requiring a hand calculator
(d) Graphs and graphical explanations
(e) Design information based on simplified strength models
(f) Other limit states accounted for by minimum dimensions
(g) Conservative loads and simplified analysis guidelines
(h) Simplified geotechnical information to help define soil-bearing capacity
(i) Shear walls as the seismic-force-resisting system
(j) Material and construction guidelines based on commonly available steel grades and medium-strength concrete that can be site mixed.
Keywords: concrete quality; foundation design; frame analysis; inspection; low-rise building construction; low-rise structure; mixing; placing; section analysis; seismic design; simplified design; specifications; structure design; structure layout.
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  • Dell_Brett, babakfeyzi, PinkPant, milova, subin91, odiclas, Umer.Aleem
  [CivilEA Exclusive] ACI PRC-440.14-25: Design of Circular Concrete-Filled Fiber-Reinforced Polymer Tubes poolmand 0 2,066 08-17-2025, 10:25 AM
  ACI E702.5: Designing Concrete Structures: Slender Reinforced Concrete Wall Design - poolmand 0 1,337 08-28-2024, 05:32 AM
  ACI 343: Analysis and Design of Reinforced Concrete Bridge Structures noelda2 3 4,737 05-12-2024, 10:46 AM
  ACI SP-344: Examples for the Design of Reinforced and Prestressed Concrete Members Un poolmand 0 1,589 03-04-2024, 08:35 AM
  ACI SP-343: Fibre Reinforced Concrete: From Design to Structural Applications poolmand 0 1,651 03-04-2024, 07:50 AM
  ACI 549.4: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Ce poolmand 0 1,475 01-23-2024, 12:10 PM
  ACI 526: Guide for Design and Construction with Autoclaved Aerated Concrete Panels poolmand 0 1,693 01-17-2024, 07:27 AM
