Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis THE EFFECT OF BOLTED FRAMES ON THE EARTHQUAKE RESISTANCE OF STRUCTURAL STEEL BUILDING
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
02-08-2013, 10:10 PM
THE EFFECT OF BOLTED FRAMES ON THE EARTHQUAKE RESISTANCE OF STRUCTURAL STEEL BUILDINGS
Author: Gunseli Yeliz Firat | Size: 7.89 MB | Format: PDF | Quality: Unspecified | Publisher: Gunseli Yeliz Firat | Year: 2006 | pages: 394
[Image: 76196811833267816990.jpg]
Observations after the 1994 Northridge earthquake revealed the limited ductility
capacity of welded connections. It has been established that typical welded connections
are susceptible to abrupt stiffness and strength loss at rotations as low as 1/10th of the
presumed ductility capacity. Furthermore, variations in the ductility capacity of
“improved” welded connections reflect the effects of inevitable variations in the weld
quality. It has also been demonstrated that bolted frames originally designed for gravity
loads retain their lateral load resisting capacity up to interstory drift ratios of three
percent. In this study, the possibility of improving the earthquake resistance of structural
steel buildings by utilizing the stable and ductile response of bolted frames was
investigated. Based on a satisfactory limit to interstory drift ratio set as two percent, the
earthquake resistances of representative three- and nine-story steel buildings designed for
regions of high seismicity were found to be inadequate. Reductions in the interstory drift
ratios were obtained by increasing the stiffness of bolted interior frames. Ultimately, it
was demonstrated that, subjected to equal ground-motion demands, buildings with bolted
frames are more likely to sustain interstory drift ratios not exceeding two percent than
comparable buildings with welded perimeter frames and bolted interior frames.
[-] The following 13 users Like asim99's post:13 users Like asim99's post
  • 3fan, Dell_Brett, joker™, ting tsai huang, malc, kowheng, blaze, cace-01, slowet, andersen3, eliseo.as, mahyarov, carolinandra
  SEISMIC DESIGN OF FRICTION DAMPED BRACED STEEL PLANE FRAMES BY ENERGY METHODS TAFATNEB 0 1,686 08-31-2013, 01:09 PM
  SEISMIC ANALYSIS OF KNEE ELEMENTS FOR STEEL FRAMES TAFATNEB 0 1,556 08-26-2013, 11:43 PM
  P-Delta Effects on Steel Moment Frames with Reduced Beam Section Connection asim99 1 1,944 02-27-2013, 11:29 PM
Last Post: LiviuM
  P-Delta Effects on Steel Moment Frames with Welded Flange Plate Connections asim99 0 1,636 02-26-2013, 04:37 PM
Last Post: asim99
  Multi-scale computational simulation of progressive collapse of steel frames david-smith 2 2,511 06-02-2012, 05:25 PM
Last Post: ssobhan
