Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Linear and Non- Linear Flexural Stiffness Models for Conc Walls in High-Rise Building
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
01-15-2013, 10:15 PM
Linear and Non- Linear Flexural Stiffness Models for Conc Walls in High-Rise Buildings
Author: Ahmad M. M. Ibrahim | Size: 5.76 MB | Format: PDF | Quality: Unspecified | Publisher: Ahmad M. M. Ibrahim | Year: 2000 | pages: 167
[Image: 35983215813083314333.jpg]
In the seismic design of high-rise wall buildings;, the fundamental period of the building and the building drift are usually determined using linear elastic dynamic analysis. To carry out this analysis, designers need to assume a linear flexural stiffhess of the wall sections that account for
cracking. The commentary to the 1994 Canadian concrete code (CPCA 1995) suggests a stiffness value of 70% of the gross moment of inertia (I g) of the wall section. The commentary to the 1995 New Zealand Standard (NZS 3101 1995) suggests much lower stiffhess values. A wall subjected to axial compression of 10% of fc! Ag is suggested to have half what is recommended in the CPCA Handbook (i.e. 0.35 lg). The NEHRP Guidelines for the Seismic Rehabilitation of
Buildings (FEMA 273) suggests stiffness values of 0.8 Ig and 0.5 Ig for uncracked and cracked concrete walls, respectively. While it is not clear which of the recommended stiffness values should be used, it is certainly clear that the choice of stiffness value will have a significant
influence on the predicted period and drift of the building.
The actual influence of cracking on the flexural stiffness of a concrete wall subjected to seismic loading is nonlinear. Nonlinear static analysis is increasingly used to capture this influence provided that an appropriate nonlinear model is used for the materiaL In this thesis, a simple nonlinear flexural (bending moment-curvature) model for concrete walls
in high-rise buildings is proposed. To validate the model, a 40ft high slender concrete wall was constructed and tested under simulated earthquake loading. Results from the test were compared with the proposed model and showed good agreement. Based on the proposed piece-wise linear model, a general method to determine the linear "effective" flexural stiffness of concrete walls was developed. Results from the general method for the effective flexural stiffness showed that the large variation in effective stiffness that is recommended by various design guidelines does actually exist for different wall configurations under certain conditions. The general method presented in this thesis gives the appropriate stiffness for a particular wall considering all important parameters that influence the stiffhess. A study was conducted to examine the influence of a variety of parameters on the stiffness of concrete walls and a set of simplified
expressions are proposed for the effective flexural stiffness of concrete walls.
[-] The following 8 users Like asim99's post:8 users Like asim99's post
  • jcbv, faros3000, kowheng, malc, devilmaycry, Sumatra, Dell_Brett, mahyarov
  Non-linear analysis of a collapsed reinforced concrete chimney mybest 1 3,862 11-06-2020, 08:17 AM
  the contribution of no structural component to the overall dynamic behavior of conc TAFATNEB 0 1,528 08-08-2014, 04:11 PM
  Using Non-Linear Vibration Techniques to Detect Damage in Concrete Bridges TAFATNEB 0 1,574 08-08-2014, 01:55 PM
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,668 05-30-2014, 02:05 PM
  A model for the non linear dynamic analysis of reinforced concrete and masonry framed TAFATNEB 0 1,619 04-02-2014, 12:42 PM
  MULTI-HAZARD DESIGN OF MID- TO HIGH-RISE STRUCTURES TAFATNEB 0 1,712 09-08-2013, 08:52 PM
  Optimal Conceptual Design of High-Rise Office Buildings asim99 1 2,312 02-27-2013, 11:55 PM
Last Post: LiviuM
