Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Paper from ICE Library
[Request] Paper from ICE Library
 apocalipse
Portugal
User ID: 41527
Threads: 105
Likes: 790 in 87 posts
Given Likes: 922
01-14-2013, 10:22 PM
Movement in a seven storey reinforced concrete frame
Authors:
J. P. Forth; J. J. Brooks ; P. R. Bingel
Abstract:
The construction of a seven storey reinforced concrete (RC) frame at the Building Research Establishment's Large Building Test Facility in Cardington, (the European Concrete Building Project) provided an ideal opportunity to obtain long-term movement data for a number of different standard and innovative concrete mix designs and to assess the accuracy of existing design methods for predicting elasticity, shrinkage and creep. The investigation involved monitoring the strain of a number of columns of the RC frame and carrying out creep and shrinkage tests on small concrete specimens over a period of nine months. The columns were made from concrete having grade strengths from 37 to 85 MPa and contained mineral and chemical admixtures. The actual movements were then compared with movements predicted from the corresponding small concrete prism measured test data using established prediction methods. The results of the analysis indicated that the movements of the columns within the RC frame were predicted to within the range of 10–20%. In addition, elastic, creep and shrinkage movements of the small concrete prisms can be predicted satisfactorily by the CEB-FIP Model Code 90.
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
01-15-2013, 07:48 AM
[-] The following 3 users Like hich's post:3 users Like hich's post
  • apocalipse, malc, tluc
 rusty
Hungary
User ID: 17227
Threads: 68
Likes: 1,880 in 283 posts
Given Likes: 539
01-16-2013, 08:47 AM
I would highly appreciate if someone could share these publications:
Collings, D. (2006). An environmental comparison of bridge forms
Proceedings of the ICE - Bridge Engineering, Volume 159, Issue 4.pages 163 –168 , ISSN: 1478-4637, E-ISSN: 1751-7664
Zhang, C. (2010).Delivering sustainable bridges to help tackle climate change
Proceedings of the ICE - Engineering Sustainability, Volume 163, Issue 2.pages 89 –95 , ISSN: 1478-4629, E-ISSN: 1751-7680
Thank you in advance.
Maybe this thread could be similar to those of ASCE and ScienceDirect.
 hich
User ID: 3732
Threads: 93
Given Likes: 101
01-16-2013, 07:09 PM
[-] The following 2 users Like hich's post:2 users Like hich's post
  • rusty, tluc
  [REQUEST] Paper from ICE Virtual Library essenza 15 6,698 11-25-2014, 11:09 AM
Last Post: ska51
  [REQUEST] ICE Virtual Library Paper s0p9015 3 2,192 01-29-2014, 07:05 AM
Last Post: ska51
  [REQUEST] ice virtual library paper chrono146 10 4,332 01-27-2014, 04:26 AM
Last Post: ska51
  [REQUEST] A paper from ACM digital library ssobhan 0 1,350 02-21-2013, 12:38 PM
Last Post: ssobhan
