Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis THE EFFECT OF HIGH STRENGTH CONCRETE ON THE BONDABILITY OF PRESTRESSING STRANDS
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
12-31-2012, 02:35 AM
Author: EDEN TESSEMA | Size: 1.54 MB | Format: PDF | Quality: Unspecified | Publisher: EDEN TESSEMA | Year: 2000 | pages: 157
[Image: 48544907696596135893.jpg]
Adequate bond between prestressing strand and concrete is essential for adequate structural performance and reliability of concrete members. Bond quality affects transfer and development lengths of prestressed members. If the bond between the strand and concrete is not enough, the transfer and development length of the member may exceed the code requirement. Hence non ductile failure occurs due to inadequate shear reinforcement provision. Researchers found the current code equations governing the bond of strand have been shown to be inaccurate. Hence bond test is needed that will help to determine the effects on bond of variations in concrete properties or constituent materials. The Prestress Concrete Institute (PCI) financed projects that investigated strands manufactured by various manufacturers using various test methods. Research conducted by Cousin,
Johnson and Zia indicates that the ACI code equations for bond might be inadequate and more research is needed to fully understand the bond mechanics between concrete and
prestressing strand. According to Mote (2001), concrete strength would affect bond of prestessing strand.
[-] The following 4 users Like asim99's post:4 users Like asim99's post
  • Dell_Brett, malc, thebeatles, Rami11
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,669 05-30-2014, 02:05 PM
  EVALUATION OF HIGH STRENGTH CONCRETE PRESTRESSED BRIDGE GIRDER DESIGN - Msc Thesis asim99 1 2,185 11-17-2013, 08:49 AM
Last Post: st77bel
  Seismic Demands in High Rise Concrete Walls asim99 1 2,045 02-09-2013, 03:49 AM
Last Post: Sumatra
  Full-Scale Experimental & Analytical Studies on High Strength Concrete Columns asim99 0 1,650 01-15-2013, 10:07 PM
Last Post: asim99
  Uniaxial and Triaxial Behavior of high strength concrete with and without steel fibe asim99 0 1,570 11-27-2012, 10:32 PM
Last Post: asim99
  EVALUATION OF HIGH STRENGTH CONCRETE PRESTRESSED BRIDGE GIRDER DESIGN|2003 Haseeb Jamal 2 2,466 02-19-2012, 02:18 AM
Last Post: Jackass
