Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis DEVELOPMENT OF A DESIGN METHODOLOGYFORSTEELFRAME/WOOD PANEL SHEAR WALLS
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
12-01-2012, 02:30 AM
Author: Aaron E. Branston | Size: 13.85 MB | Format: PDF | Quality: Scanner | Publisher: Aaron E. Branston | Year: 2004 | pages: 215
[Image: 55951457436459109506.jpg]
It is anticipated that the construction of homes and multiple storey buildings which
incorporate light gauge steel frame I wood panel shear walls as primary lateral load
resisting elements will increase across Canada in coming years. This includes sites
that have a relatively high seismic risk, such as found along the West Coast of
British Columbia and in the Ottawa and St. Lawrence River Valleys. With this rise
in construction activity comes an accompanying increase in the probability that a
light gauge steel frame structure will be subjected to the demands of a severe
earthquake. Currently, guidelines for engineers with which the design of laterally
loaded light gauge steel frame I wood panel shear walls can be carried out are not
available in Canada. For this reason an extensive shear wall research program has
been undertaken at McGill University.
This thesis provides details on the 109 specimen main testing program as well as a
summary of past wood frame and steel frame shear wall research. An extensive
review of existing data interpretation methodologies is presented. The equivalent
energy elastic-plastic (EEEP) technique is chosen as most suitable for the wall
systems under study to deduce key design parameters including the yield wall
resistance, elastic stiffness, and system ductility. It is recommended that the EEEP
methodology be implemented for all future steel frame I wood panel shear wall
data interpretation. The calibration of a resistance factor for use with the limit
states design philosophy consistent with the upcoming draft version of the 2005
National Building Code of Canada (NBCC) is also presented.
It was found that a resistance factor (<l>) of 0.7 provided sufficient reliability and a
reasonable factor of safety under the NBCC wind loading case. Final nominal
strength and unit elastic stiffness values for use in design are presented in tabular
format according to given perimeter fastener schedules. Finally, recommendations
for future research and testing are outlined.
[-] The following 4 users Like asim99's post:4 users Like asim99's post
  • malc, ykhackhack, eliseo.as, Dell_Brett
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,807 03-27-2015, 11:44 AM
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 1,820 10-08-2014, 02:00 PM
  A Study of the Progressive Degradation of Masonry Shear Walls Subjected to Harmonic L TAFATNEB 0 1,641 06-04-2014, 12:00 AM
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,669 05-30-2014, 02:05 PM
  SHEAR STRENGTH OF PARTIALLY GROUTED SQUAT MASONRY SHEAR WALLS TAFATNEB 0 1,493 11-02-2013, 12:40 PM
  Behavior and Vulnerability of Reinforced Masonry Shear Walls TAFATNEB 0 1,693 11-02-2013, 10:54 AM
  T. Paulay PhD Thesis: The coupling of shear walls hm20284 2 2,282 10-17-2012, 05:13 PM
Last Post: Diquan
