Civil Engineering Association eBooks Structural Books Concrete Evaluation, Presentation and Repair of Microbial Acid-Produced Attack of Concrete
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-17-2012, 12:41 PM
Author: Hu, Jiong Hahn, Dittmar Rudzinski, Walter Wang, Zhuo Estrada, Luzelva | Size: 8.39 MB | Format: PDF | Quality: Original preprint | Publisher: Texas State University, San Marcos | Year: 2011 | pages: 228
[Image: 45806594070913368596.png]
The Texas Department of Transportation (TxDOT) has approximately 50,000 bridges in its inventory and the deterioration of concrete under these bridges, most of which are reinforced, has been a critical issue affecting the service condition. Recent research on deteriorated concrete columns on bridges in Texas indicated that microbial colonization might be a factor promoting the surface deterioration of bridge columns continuously exposed to water. Although microbial activities may be involved in the surface deterioration, it is however not clear how severe the deterioration is and whether it is a significant contributor to the deterioration. Field and laboratory investigations are needed to identify the impact of microbial induced deterioration (MID) on TxDOT bridges. To evaluate the severity of the deterioration and determine whether MID is a significant contributor to the deterioration, visual inspection and a number of in situ tests were performed on columns of twelve selected TxDOT bridges. Laboratory tests including microbial, chemical composition, mineralogy and petrographic analyses were performed to investigate the potential cause and extent of the deterioration. Results from this comprehensive study were used to provide evidence of concrete degradation and ascertain the degree of deterioration caused by microbial attack. The study also evaluated the effectiveness and consistency of various measurements used in this study and provided a suggested test procedure to identify microbial attack on concrete and evaluate the integrity of deteriorated concrete due to the attack. In addition, a preliminary evaluation of the microbial attack resistance of commonly used TxDOT mixes was performed through evaluation of resistance of a series of mixes subjected to field and/or sulfuric acid solution exposure.
[-] The following 3 users Like mahyarov's post:3 users Like mahyarov's post
  • kowheng, blaze, Dell_Brett
  CS TR?: Assessment, Design and Repair of Fire-Damaged Concrete Stuctures ir_71 6 12,740 08-27-2025, 03:39 AM
Last Post: concreteok
  Corrosion of Steel In Concrete: Understanding, investigation and repair Grunf 12 8,088 12-25-2022, 10:10 PM
Last Post: carolinandra
  CS TR 69 - Repair of concrete structures with reference to BS EN 1504 ir_71 2 3,132 02-06-2022, 12:32 PM
Last Post: babakfeyzi
  Concrete Repair: A Practical Guide cace-01 6 5,044 02-06-2022, 11:44 AM
  Concrete Repair to EN 1504: Diagnosis, Design, Principles and Practice r3be1 3 3,625 11-16-2019, 09:08 AM
  Appraisal and Repair of Reinforced Concrete febo927 0 2,150 07-16-2018, 08:06 PM
Last Post: febo927
  The Repair of Concrete Structures, 2nd ed, 1993 febo927 1 1,692 05-29-2018, 03:26 PM
Last Post: axcel
