Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Laser Welded Steel Sandwich Panel Bridge Deck Development
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-13-2012, 10:35 AM
Laser Welded Steel Sandwich Panel Bridge Deck Development: Finite Element Analysis and Stake Weld Strength Tests
Author: Caccese, Vincent | Size: 4.34 MB | Format: PDF | Quality: Original preprint | Publisher: University of Maine, Orono | Year: 2009 | pages: 108
[Image: 89626819651541519162.png]
This report summarizes the analysis of laser welded steel sandwich panels for use in bridge structures and static testing of laser stake welded lap shear coupons. Steel sandwich panels consist of two face sheets connected by a relatively low-density core resulting in high strength and stiffness, which leads to promising design advantages. Steel sandwich panels offer substantial resistance to static and dynamic loads due to their high stiffness and substantial energy absorbing capacity. Panels of this kind are of interest for potential use in bridges for deck replacement. They are especially efficient in resisting dynamic events such as fatigue, impact or shock loading. A verification study is performed comparing finite element analysis and an analytical model to an experimental study documented in the literature. Results demonstrate good agreement between the approaches. Modeling techniques are developed from the verification study. Finite element analyses are subsequently employed to study the response of a laser welded steel sandwich panel case study of a deck replacement for a steel bridge located in Gardiner, Maine. The deck design results in a stiff structure that has a deflection of 1/1500 of the span at a depth of 7.25 inches. Structural response of stake welds was also investigated experimentally in a single lap shear configuration. Multiple pass welds consisting of 2 and 4 stake weld passes were fabricated and tested to assess the process of using multi-passes to increase weld resistance.
[-] The following 2 users Like mahyarov's post:2 users Like mahyarov's post
  • blaze, kowheng
  Bridge Deck Analysis Flexi 10 9,772 08-19-2019, 10:22 PM
Last Post: Nita1391
  FRP Deck and Steel Girder Bridge Systems ir_71 4 3,538 09-25-2018, 01:01 PM
Last Post: febo927
  Bridge Deck Analysis from Pama - Cusens gianniorlati 2 2,940 02-06-2018, 11:13 PM
Last Post: Kurucz
  Grillage analogy in Bridge Deck Analysis Dell_Brett 3 4,650 07-03-2016, 06:09 AM
Last Post: Dell_Brett
  Analysis of Beam Grids and Orthotropic Plates - Bridge Deck Design gianniorlati 1 2,564 10-06-2015, 06:35 AM
Last Post: subin91
  Bridge Deck Behaviour, 2nd Edition Flexi 8 6,008 01-22-2014, 05:19 PM
Last Post: ssobhan
  Development of a Stand-Alone Concrete Bridge Pier Protection System mahyarov 0 1,477 11-12-2012, 08:49 PM
Last Post: mahyarov
