Civil Engineering Association eBooks Structural Books Concrete Validation of Prestressed Concrete I-Beam Deflection and Camber Estimates
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-29-2012, 06:27 AM
Author: O’Neill, Cullen R French, Catherine E | Size: 3.34 MB | Format: PDF | Quality: Original preprint | Publisher: University of Minnesota, Twin Cities | Year: 2012 | pages: 205
[Image: 24469382403815710275.png]
The camber at the time of bridge erection of prestressed concrete bridge girders predicted by the Minnesota Department of Transportation (MnDOT) was observed to often overestimate the measured cambers of girders erected at bridge sites in Minnesota, which, in some cases, was causing significant problems related to the formation of the bridge deck profile, the composite behavior of the girders and bridge deck, delays in construction and increased costs. Extensive historical data was collected from two precasting plants and MN counties and it was found that, on average, the measured cambers at release and erection were only 74% and 83.5%, respectively, of the design values. Through data collection, analysis, and material testing, it was found that the primary causes of the low camber at release were concrete release strengths that exceeded the design values, the use of an equation for concrete elastic modulus that greatly under-predicted the measured values, and thermal prestress losses not accounted for in design. Fourteen girders were instrumented and their camber measured and the program PBEAM was used to evaluate the influence of various time-dependent effects (i.e., solar radiation, relative humidity, concrete creep and shrinkage, length of cure and bunking/storage conditions) on long-term camber. Once investigated, these effects were included in long-term camber predictions that were used to create sets of both time-dependent and singlevalue camber multipliers. The use of these multipliers, along with modifications made to the elastic release camber calculations, greatly reduced the observed discrepancy between measured and design release and erection cambers.
[-] The following 7 users Like mahyarov's post:7 users Like mahyarov's post
  • blaze, cace-01, kowheng, gulilero, oanm2000, SCREAM7890, pram
  An Introduction to Prestressed Concrete usman 4 5,479 08-10-2024, 06:08 AM
  Guide Specifications for the Design of Concrete Bridge Beams Prestressed with Carbon poolmand 2 3,421 08-30-2023, 08:59 AM
  Reinforced and prestressed Concrete Design to EC2 - The complete Process gianniorlati 3 3,067 12-20-2022, 08:37 AM
Last Post: Dell_Brett
  Analysis and Design of Prestressed Concrete carolinandra 0 1,620 09-24-2022, 03:53 PM
Last Post: carolinandra
  PRESTRESSED CONCRETE. 5ED carolinandra 0 1,543 06-28-2022, 12:38 PM
  CPCI: Canadian Precast & Prestressed Concrete Institue - Design Manual 4 rohailiyaz 6 4,806 06-23-2022, 04:40 AM
Last Post: sandeepb
  Reinforcement Detailing Handbook for Reinforced and Prestressed Concrete carolinandra 0 1,591 01-29-2022, 08:01 PM
