Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Load and Resistance Factor Design (LRFD) for Reliability Analysis/Design of Piles Axi
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-28-2012, 05:57 AM
Load and Resistance Factor Design (LRFD) for Reliability Analysis/Design of Piles Axial Capacity
Author: Rahman, M Shamimur | Size: 3.28 MB | Format: PDF | Quality: Original preprint | Publisher: North Carolina State University, Raleigh | Year: 2002 | pages: 347
[Image: 21388459274400379675.png]
Resistance factors were developed for use as a part of the implementation of the Load and Resistance Factor Design (LRFD) method of driven piles’ axial capacity. Resistance factors were calibrated in the framework of reliability theory utilizing pile load test data available from North Carolina Department of Transportation (NCDOT). Resistance statistics were evaluated for each data case in terms of bias factors. Reliability analyses on the current practice of pile foundation design by the Vesic, Meyerhof, and Nordlund methods were performed to evaluate the level of safety and to select target reliability indexes. Two types of First Order Reliability Method, Mean Value First Order Second Moment method and Advanced First Order Second Moment method, were employed for the reliability analysis and the calibration of the resistance factors. Recommended resistance factors for the three design methods (Vesic, Meyerhof, and Nordlund) are presented for the target reliability indexes of 2.0 and 2.5. Seven design categories for which the resistance factors are recommended are coastal concrete square pile with N@Toe<=40, coastal concrete square pile with N@Toe>40, coastal steel HP pile, coastal steel pipe pile, coastal concrete cylinder pile, piedmont concrete square pile, and piedmont steel HP pile. The resistance factors were calibrated separately for total, skin and toe capacities in an attempt to develop a correlation between the three resistance factors for each design category. In many cases, however, the resistance factor for total capacity is larger than both the skin and toe resistance factors and only total capacity factors are recommended. The resistance factors developed and recommended from this research are specific for the distinct soil types of North Carolina and for the unique practice of pile foundation design in the NCDOT.
  • rendel_©, blaze, cace-01, Evandrojr, alibouafia, zinousoft
  Design of Piles Under Cyclic Loading: SOLCYP Recommendations OSHO 0 1,689 06-22-2019, 12:42 AM
Last Post: OSHO
  Helical Piles: A Practical Guide to Design and Installation hich 8 5,688 07-03-2016, 06:22 AM
Last Post: Dell_Brett
  Rapid Load Testing on Piles: Interpretation Guidelines lamkin 5 3,653 05-04-2015, 12:53 PM
Last Post: PinkPant
  New Design Methods for Offshore Piles PinkPant 0 1,435 05-04-2015, 12:39 PM
Last Post: PinkPant
  Reliability-Based Design in Geotechnical Engineering: Computations and Applications oanm2000 7 4,817 11-06-2014, 04:57 AM
Last Post: r3be1
  Rapid Load Testing on Piles abudabeeja 5 3,541 10-21-2014, 06:46 PM
Last Post: r3be1
  USDOT: Drilled Shafts: Construction Procedures and LRFD Design Methods isurya 4 3,885 11-22-2012, 03:46 PM
Last Post: miquan
