Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Seismic Behavior and Retrofit of Bridge Knee Joint Systems
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 04:14 PM
Seismic Analysis of Retaining Walls, Buried Structures, Embankments, and Integral Abutments
Author: McLean, David I | Size: 2.11 MB | Format: PDF | Quality: Unspecified | Publisher: Washington State Transportation Center | Year: 2005 | pages: 82
[Image: 56849457085573998936.png]
Experimental tests were conducted on seven 1/3-scale specimens to define the vulnerabilities of existing outrigger bents under in-plane and out-of-plane seismic loading and to develop appropriate retrofit measures that address the identified vulnerabilities. The specimens represented bents with short and long outrigger beams in the SR-99 Spokane Street Overcrossing in western Washington State. The as-built specimens failed at low ductility levels due to shear distress, low torsional strength of the beam, and reinforcement bond failures within the joint. Circular and D-shaped steel jackets were used to retrofit the regular and split as-built specimens, respectively. The retrofitted specimens developed plastic hinging in the column, with enhanced strength, energy and ductility capacities. Threshold principal tension stress values describing the expected condition of the joints were established and compared to values obtained by other researchers. Design and detailing guidelines for retrofitting outrigger bents were proposed. The guidelines include equations for the jacket thickness required to form a stable force transfer mechanism between the beam and the column reinforcement as well as to prevent joint failure.
  • blaze, cace-01, mgdario, carolinandra, kowheng
  FRP Deck and Steel Girder Bridge Systems ir_71 4 3,542 09-25-2018, 01:01 PM
Last Post: febo927
  FIB 39: Seismic bridge design and retrofit- structural solutions lamkin 5 4,868 04-03-2014, 07:32 AM
Last Post: junaid
  Simplifying Bridge Expansion Joint Design and Maintenance mahyarov 0 1,824 11-17-2012, 12:31 PM
Last Post: mahyarov
  Retrofit of Rectangular Bridge Columns Using CFRP Wrapping mahyarov 0 1,479 11-12-2012, 08:46 PM
Last Post: mahyarov
  Prefabricated/Precast Bridge Elements and Systems (PBES) for O-System Bridges mahyarov 0 1,586 11-10-2012, 07:46 AM
Last Post: mahyarov
  Behavior of Field-Cast Ultra-High Performance Concrete Bridge Deck Connections Under mahyarov 0 1,691 11-07-2012, 02:40 PM
Last Post: mahyarov
  Bridge Deck Joint Performance mahyarov 0 1,385 10-27-2012, 06:41 AM
Last Post: mahyarov
