Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering A pre-cast concrete bridge bent designed to re-center after an earthquake
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 02:39 PM
Author: Cohagen, L Pang, J B Eberhard, M O Stanton, J F | Size: 2.97 MB | Format: PDF | Quality: Original preprint | Publisher: Washington State Department of Transportation | Year: 2008 | pages: 105
[Image: 15223680743762547059.png]
In this study the post-earthquake residual displacements of reinforced concrete bridge bents were investigated. The system had mild steel that was intended to dissipate energy and an unbonded, post-tensioned tendon that was supposed to remain elastic and re-center the column. The columns tested had different mild steel to prestress ratios, which affected their re-centering ability. Two 40 percent scale specimens with large-bar connection details and a central unbonded, post-tensioned tendon were tested by using pseudo-static loading. The large-bar system is a rapidly constructible precast system for use in seismic regions. The test columns had re-centering ratios of 1.6 and 1.2. A column with the same connection details but no prestress and a re-centering ratio of 0.9 was used as a reference. The displacement at zero force in the test was used as a proxy for the residual displacement after an earthquake. The tests showed that columns with a larger re-centering ratio did experience lower residual drifts, although this distinction only became clear for drift ratios that exceeded 2 percent. The tests also showed that increases in post-tensioning force led to slight increases in damage at high drift ratios.
[-] The following 3 users Like mahyarov's post:3 users Like mahyarov's post
  • cace-01, kowheng, ruaumoko
  A Precast Bridge Bent System for Seismic Regions mahyarov 0 1,687 11-12-2012, 08:42 PM
Last Post: mahyarov
  Seismic Assessment and Retrofit of Existing Multi-Column Bent Bridges mahyarov 0 1,496 10-27-2012, 03:55 PM
Last Post: mahyarov
  Seismic Performance of an I-Girder to Inverted-T Bent Cap Connection mahyarov 0 1,394 10-27-2012, 01:43 PM
Last Post: mahyarov
  NEHRP TB3: Seismic Design of Cast-in-Place Concrete Diaphragms, Chords and Collectors parhyang 1 2,379 07-06-2012, 05:19 AM
Last Post: shadabg
  NEHRP TB6: SEISMIC DESIGN OF SPECIAL CAST IN PLACE CONCRETE SPECIAL STRUCTURAL WALL aslam 0 1,705 12-02-2011, 05:40 AM
Last Post: aslam
  Dynamics Behaviour of Reinforced Concrete Frames Designed with Direct Displacement B miquan 1 2,480 03-23-2011, 09:37 AM
