Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Elastomeric Bridge Bearings: Recommended Test Methods
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-24-2012, 01:14 PM (This post was last modified: 10-24-2012, 01:16 PM by mahyarov.)
Author: Yura, J KUMAR, A Yakut, A Topkaya, C Becker, E Collingwood, J | Size: 3.58 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2001 | pages: 124 | ISBN: 0309066670
[Image: 19309108333626489739.png]
Fifteen tests currently required by the American Association of State Highway and Transportation Officials (AASHTO) for determining the properties of elastomeric bridge bearings were evaluated with respect to their effect on the performance of the bearing. Experimental research was conducted in principally four areas: shear modulus, aging, creep, and low temperature. Theoretical studies were undertaken on the effect of misaligned steel laminates on the stresses and deformation within the elastomeric bearing. It was found that significant misalignments do not have a significant effect on the internal stresses and strains. Crack growth studies established that ozone induced surface cracks or cracks from manufacturing defects on the surface will not propagate significantly into the bearing within its lifetime. Delaminations at the interface of the elastomer and steel laminate were found to be very significant, so bearings with such defects should be rejected. Three new test methods were developed: an inclined compression test, a creep test and a compressive stiffness test. The inclined compression test was developed primarily to determine the shear modulus of the elastomer, but it can also be used to determine the shear bond strength and the compressive stiffness of the bearing. The elimination of eight current test procedures in AASHTO is recommended. New low temperature bearing performance criteria were developed because the current criteria unnecessarily restrict the use of certain elastomeric material.
[-] The following 9 users Like mahyarov's post:9 users Like mahyarov's post
  • kowheng, warlord1, blaze, jcbv, cace-01, bhowmik, pezhmankhan, Dell_Brett, draluka
  Bridge Engineering: Classifications, Design Loading, and Analysis Methods pezhmankhan 0 1,913 06-25-2018, 06:15 AM
Last Post: pezhmankhan
  Bridge Bearings and Expansion Joints - by David J Lee triance 3 4,710 12-11-2015, 12:42 PM
  NCHRP R432 - High-load multi-rotational bridge bearings ibg0203 0 1,518 10-21-2015, 05:52 PM
Last Post: ibg0203
  Design rules for bridge bearings and expansion joints mahyarov 2 2,770 12-05-2014, 10:00 PM
Last Post: monter
  NCHRP - R697 A Comparison of AASHTO Bridge Load Rating Methods mahyarov 1 2,303 04-25-2014, 06:22 AM
Last Post: arshiakh
  Damage Detection and Repair Methods for GFRP Bridge Decks mahyarov 0 1,488 10-29-2012, 06:53 AM
Last Post: mahyarov
  Seismic Testing of Precast Segmental Bridges: Phase III: Bridge System Test mahyarov 0 1,559 10-27-2012, 04:17 PM
Last Post: mahyarov
