Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Damage Detection and Repair Methods for GFRP Bridge Decks
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-29-2012, 06:53 AM
Author: Asencio, Rafael Brown, Jeff R | Size: 8.50 MB | Format: PDF | Quality: Original preprint | Publisher: University of Florida, Gainesville | Year: 2011 | pages: 193
[Image: 71850593404174318162.png]
Glass fiber-reinforced polymer (GFRP) decks are being considered for use as a replacement for worn steel grid bridge decks due to their high strength-to-weight ratio and fast installation time. In this research, two nondestructive evaluation techniques were considered for use in evaluating in-service GFRP bridge decks for damage: acoustic emissions (AE) and infrared thermography (IRT). Three different commercially available deck systems were tested in positive and negative bending test setups. The testing consisted of loading each specimen sequentially with service, then ultimate, then service level loads, which provided AE data for both undamaged and damaged deck specimens. Damage was induced on the specimens by loading them to their ultimate capacity. The specimens generally exhibited linear elastic behavior up to failure. AE feature data were evaluated using intensity analysis and recovery ratio analysis (RRA). The recovery ratio analysis was adapted from calm ratio analysis, which is based on the Kaiser effect. RRA provided clear distinction between damaged and undamaged decks in all three specimens. Evaluation criteria based on this method are proposed. A modified form of RRA was then used on data collected during a bridge load test of the Hillsboro canal bridge in Belle Glade, Florida.. Initial IRT work required finite element simulation of the heat transfer process to determine optimal heating and data acquisition parameters that were used to inspect GFRP bridge decks in the laboratory. Experimental testing was performed in a laboratory setting on damaged and undamaged GFRP bridge deck specimens from three different manufacturers. IRT evaluation focused on identifying damage in the specimens that had been loaded to their ultimate flexural strength. It was demonstrated that IRT successfully identified features of two types of GFRP bridge decks and that severe delamination/debonding could be detected under ideal circumstances. Additional research is needed to improve detection of severe damage, including methods to reduce the interference of surface imperfections, such as non-uniform heating, which are inherent to the GFRP bridge decks examined in the current study.
  • blaze, kowheng, oanm2000, SCREAM7890
  Concrete Bridge Strengthening and Repair carolinandra 0 1,686 11-27-2018, 06:56 AM
Last Post: carolinandra
  Bridge Engineering: Classifications, Design Loading, and Analysis Methods pezhmankhan 0 1,910 06-25-2018, 06:15 AM
Last Post: pezhmankhan
  Bridge and Highway Structure Rehabilitation and Repair Learner 18 10,451 11-02-2015, 05:53 PM
Last Post: ibg0203
  Advanced Composites in Bridge Construction and Repair amindoxiti 1 2,179 04-17-2015, 10:06 AM
Last Post: Dell_Brett
  Bridge Decks: Design, Construction, Rehabilitation, Replacement amindoxiti 0 1,716 01-06-2015, 04:08 PM
  NCHRP - R697 A Comparison of AASHTO Bridge Load Rating Methods mahyarov 1 2,296 04-25-2014, 06:22 AM
Last Post: arshiakh
  Bridge Management: Inspection, Maintenance, Assessment and Repair babak 2 2,978 03-01-2013, 04:31 PM
Last Post: arshiakh
