Civil Engineering Association eBooks Structural Books Concrete Concrete Repair
Concrete Repair
 timosi™
User ID: 3890
Threads: 143
Likes: 5,532 in 394 posts
Given Likes: 1812
09-18-2009, 09:09 AM
Concrete Repair
[Image: a1onpfb20w4gonch7soa.png]
1 Introduction
1.1. Scope
1.2. Objective
1.3. References
2 Selection of Repair Materials
2.1. Description
3 Concrete Pavement
3.1. Description and Composition
3.2. Properties and Behavior
4 Full-Depth Repair of Pavements
4.1. Purpose
4.2. Need for Full-Depth Repair
4.3. Selection or Repair Boundries
4.4. Sawing of Repair Boundries
4.5. Removal of Existing Concrete
4.6. Subgrade and Base Preparation
4.7. Dowel and Tiebar Placement
4.8. Replacing Reinforcement
4.9. Expansion Joints
4.10. Filler Material
4.11. Dowels
4.12. Concrete Placement
4.13. Concrete Finishing and Texturing
4.14. Curing
4.15. Joint Sealing
5 Partial-Depth Repair of Pavements
5.1. Purpose
5.2. Need for Partial-Depth Repair
5.3. Selection of Repair Boundries
5.4. Removal of Existing Concrete
5.5. Cleaning
5.6. Joint Preparation
5.7. Patch Materials
5.8. Placement of Patch Materials
5.9. Finishing
5.10. Saw-cut Runouts
5.11. Sealing Patch/Slab Interface
5.12. Curing
5.13. Joint Resealing
6 Slabjacking
6.1. Purpose
6.2. Need for Slabjacking
6.3. Location of Injection Holes
6.4. Drilling Holes
6.5. Grout Mixtures
6.6. Grout Pumping
6.7. Elevation Control During Jacking
6.8. Plugging and Cleanup
7 Subsealing Jointed Concrete Pavements
7.1. Purpose of Subsealing
7.2. Void Detection
7.3. Need for Subsealing
7.4. Hole Patterns
7.5. Drilling Holes
7.6. Grout Mixtures
7.7. Grout Injection
7.8. Retesting Slab Corners
7.9. Plugging and Cleanup
8 Asphalt Undersealing
8.1. Method
8.2. Procedure
9 Diamond Grinding
9.1. Purpose of Grinding
9.2. Need for Grinding
9.3. Grinding Process
9.4. Test Section
9.5. Grinding Procedure
9.6. Acceptance Testing
10 Load-Transfer Restoration
10.1. Purpose
10.2. Need for Load-Transfer Restoration
10.3. Correction of Deficiencies
10.4. Methods of Load-Transfer Restoration
10.5. Patching Material
10.6. Placing
11 Polymer Concrete
11.1. Description
11.2. Surface Preparation
11.3. Polymer Concrete Patching Materials
11.4. Placement
11.5. Safety
12 Pavement-Edge Drain
12.1. Purpose
12.2. Need for Pavement-Edge Drainage
12.3. Drainage Systems
12.4. Subsurface Drain Functions
12.5. Subsurface Drain Materials
12.6. Subsurface Drain Installation
12.7. French Drains
Chapter 13 Heat-Resistant Concrete
13.1. Description
13.2. Exposure Time and Temperature
13.3. Aggregate Performances
Download Links:
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 11 users Like timosi™'s post:11 users Like timosi™'s post
  • essam2109, essam2109, vvvv, vvvv, jcoronellr, Nilupa, Clouseau, niki102, engr1900, rkce, ykhackhack
 Jackass
Semi Senior Member
Banned
Bolivia
User ID: 29460
Threads: 33
Likes: 1,138 in 115 posts
Given Likes: 7399
07-28-2011, 08:23 AM
Hi
Here is link
[-] The following 13 users Like Jackass's post:13 users Like Jackass's post
  • Clouseau, knrsa, engr1900, Adam Smith, chenamoy, vardan, Nilupa, GMianG, ranger, blaze, pram, ykhackhack, inge911
  CS TR?: Assessment, Design and Repair of Fire-Damaged Concrete Stuctures ir_71 6 12,788 08-27-2025, 03:39 AM
Last Post: concreteok
  Corrosion of Steel In Concrete: Understanding, investigation and repair Grunf 12 8,186 12-25-2022, 10:10 PM
Last Post: carolinandra
  CS TR 69 - Repair of concrete structures with reference to BS EN 1504 ir_71 2 3,158 02-06-2022, 12:32 PM
Last Post: babakfeyzi
  Concrete Repair: A Practical Guide cace-01 6 5,085 02-06-2022, 11:44 AM
  Concrete Repair to EN 1504: Diagnosis, Design, Principles and Practice r3be1 3 3,656 11-16-2019, 09:08 AM
  Appraisal and Repair of Reinforced Concrete febo927 0 2,160 07-16-2018, 08:06 PM
Last Post: febo927
  The Repair of Concrete Structures, 2nd ed, 1993 febo927 1 1,708 05-29-2018, 03:26 PM
Last Post: axcel
