Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) APA Engineered Wood Products
 ykhackhack
United States
User ID: 36960
Threads: 81
Likes: 3,670 in 707 posts
Given Likes: 8693
07-20-2012, 04:12 AM (This post was last modified: 07-20-2012, 04:31 AM by ykhackhack.)
APA ENGINEERED WOOD CONSTRUCTION GUIDE
[align=center][img][Image: 58260390811892315869.jpg][/img]
In searching the forum I found that one of the main material used these days (plywood) does not have enough space.
One of the major association globally is "APA Engineered Wood Association"
I will try to put some information here.
A Short History of APA
APA — The Engineered Wood Association is the nonprofit trade association of the U.S. and Canadian engineered wood products industry. Based in Tacoma, Washington, the Association is comprised of and represents manufacturers of structural plywood, oriented strand board (OSB), structural composite panels, glued laminated (glulam) timber, wood I-joists, and laminated veneer lumber (LVL). (See the glossary backgrounder for explanation of these products.)
APA was founded in 1933 as the Douglas Fir Plywood Association to advance the interests of the burgeoning Pacific Northwest plywood industry. Adhesive and technology improvements eventually led to the manufacture of structural plywood from Southern pine and other species, and in 1964 the Association changed its name to American Plywood Association (APA) to reflect the national scope of its growing membership.
The Association’s membership expanded again in the early 1980s with the introduction of oriented strand board (OSB), a product the Association helped bring to market through development of new panel performance standards. A decade later, APA formed a related nonprofit organization now called Engineered Wood Systems (EWS) to accommodate manufacturers of non-panel engineered wood products, such as glulam timber, wood I-joists and laminated veneer lumber.
To better reflect the broadening product mix and geographic range of its membership, the Association changed its name again in 1994 to APA—The Engineered Wood Association. The acronym “APA” was retained in the name because it was so widely known and respected in the marketplace.
Today, APA and EWS represent approximately 152 engineered wood product mills in the U.S., Canada and abroad.
You can go to their web site and sign up to have access all of this and more information
[Image: homepage.png]
(3.4 mb)
[-] The following 6 users Like ykhackhack's post:6 users Like ykhackhack's post
  • Jackass, malc, blaze, cristi, pram, monter
  Wood and Wood Joints ibg0203 0 1,700 03-02-2016, 04:07 PM
Last Post: ibg0203
  Details for Conventional Wood Frame Construction - American Wood Council Gabemzaman 2 3,314 04-11-2012, 12:47 PM
Last Post: ranger
  MANUAL FOR ENGINEERED WOOD CONSTRUCTION ir_71 0 1,816 03-07-2011, 07:07 PM
  Delamination in Wood, Wood Products and Wood-Based Composites ir_71 1 1,930 12-17-2010, 04:16 AM
