Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 544.5: Report on the Physical Properties and Durability of Fiber-Reinforced Co
07-15-2012, 07:15 PM (This post was last modified: 05-03-2023, 06:12 AM by Administrator.)
ACI 544.5R-10 Report on the Physical Properties and Durability of Fiber-Reinforced Concrete
Author: ACI Committee 544 | Size: 2.14 MB | Format: PDF | Quality: Original preprint | Publisher: ACI | Year: 2010 | pages: 35 | ISBN: 9780870313653
[Image: 21270139973133212622.jpg]
The report is divided into three sections:
1. The physical properties of FRC;
2. The areas where concrete durability is affected by the addition of fibers; and
3. A series of applications where FRC use resulted in beneficial durability.
The various properties addressed and the wide selection available in formulating matrix systems allow performancebased specification of concrete materials using fibers to
become a viable reality. The objective of this report is to provide a historical basis about current knowledge for concrete professionals to use in tailoring new, sustainable, and durable concrete mixtures.
  • Jackass, Dell_Brett, malc, aslam, simanta, kowheng, oanm2000, lisine, toa011, st77bel, ykhackhack, nhim4mat2006, bigone, davegabj
08-04-2013, 09:15 AM
  • iman_S_n, blaze, isurya, Dell_Brett, sodapas, vardan, oanm2000, malc, ykhackhack, nhim4mat2006, bigone, harsono
05-03-2023, 06:11 AM
ACI PRC-544.5-10: Report on the Physical Properties and Durability of Fiber-Reinforced Concrete
Author(s)/Editor(s): ACI Committee 544 | Size: 2.13 MB| Format: PDF| Quality: Original preprint| Year: 2010| pages: 31 | ISBN: 9780870313653
This document addresses the physical properties and durability of fiber-reinforced concrete (FRC). The effects of fiber reinforcement are evaluated for various physical, short-term, and long-term benefits they impart to the concrete mixture. A variety of test methods, conditions, and properties are reported. The various properties listed, in addition to the wide variety of the choices available in formulating matrix systems, allow performance-based specification of concrete materials using fibers to become a viable option. This document provides a historical basis and an overview of the current knowledge of FRC materials for tailoring new, sustainable, and durable concrete mixtures.
This document is divided into three sections. The first section discusses the physical properties of FRC in terms of electrical, magnetic, and thermal properties. Rheological properties, which affect fiber dispersion and distribution, are discussed using both empirical and quantitative rheology. Mechanisms of creep and shrinkage and the role of various fiber types in affecting both plastic shrinkage cracking and restrained shrinkage cracking are also addressed. The durability of concrete as affected by the addition of fibers is documented under freezing and thawing, corrosion resistance, and scaling. The durability of FRC systems is also affected as different fibers respond differently to the highly alkaline cementitious microstructure. The durability of alkali-resistant glass and cellulose fibers are studied by an in-depth evaluation of long-term accelerated aging results. Degradation and embrittlement due to alkali attack and bundle effect are discussed. Recent advances for modeling and design of materials with aging characteristics are presented. Literature on the use of FRC materials under aggressive environments, extreme temperatures, and fire is presented. The final sections list a series of applications where the use of FRC has resulted in beneficial durability considerations.
Keywords: aging; chloride permeability; corrosion; cracking; creep; diffusion; degradation; ductility; durability; electric properties; embrittlement; fiberreinforced cement-based materials; fiber-reinforced products; fire resistance; flexural strength; freezing-and-thawing; glass; microcracking; permeability; plastic shrinkage; polypropylene; polyvinyl alcohol; reinforcing materials; rheology; shrinkage cracking; steel; sulfate attack; thermal conductivity; toughness; water permeability; wood pulp.
  • Dell_Brett, PinkPant, milova, subin91
  [CivilEA Exclusive] ACI PRC-440.14-25: Design of Circular Concrete-Filled Fiber-Reinforced Polymer Tubes poolmand 0 2,091 08-17-2025, 10:25 AM
  [CivilEA Exclusive] ACI 440.13: Strengthening Structural Concrete with Fiber-Reinforced Polymer (FRP) Sys poolmand 0 1,776 12-15-2024, 06:43 AM
  ACI E702.7: Designing Concrete Structures: Carbon Fiber-Reinforced Polymer (CFRP) She poolmand 0 1,328 08-28-2024, 06:01 AM
  ACI SP-360: Proceedings of the 16th International Symposium on Fiber-Reinforced Polym poolmand 0 1,463 04-16-2024, 10:16 AM
  ACI 544.12: Performance-Based Fiber-Reinforced Concrete for Slabs-on-Ground and Overl poolmand 0 1,892 01-23-2024, 05:36 AM
  ACI 440.3: Guide Test Methods for Fiber-Reinforced Polymers (FRPs) for Reinforcin ir_71 1 2,476 05-02-2023, 09:27 AM
  ACI 440.6: Specification for Carbon and Glass Fiber-Reinforced Polymer Bar Mohammad6299 1 2,129 04-29-2023, 01:11 PM
