Civil Engineering Association eBooks Geotechnical Engineering SGCC2011 International Symposium on Sustainable Geosynthetics and Green Technology f
 utan
Japan
User ID: 30193
Threads: 135
Likes: 1,654 in 158 posts
Given Likes: 1732
06-22-2012, 06:45 AM
[Image: 28047212031230152050.jpg]
SGCC2011 International Symposium on Sustainable Geosynthetics and Green Technology for Climate Change
Size: 49.1 MB | Format: PDF | Quality: Unspecified | Publisher: Asian Institute of Technology | Year: 2011 | pages: 597
TABLE OF CONTENTS
Keynote Speakers
Asphalt Pavement Using Confined-Reinforced Earth 1
by H. Ohta, T. Ishigaki and N. Tatta
Historical Advancement of Geotechnical Engineering and their Application in Construction Industry and Beyond 9
by M. W. Bo
Stabilising Railway Embankments with Geosynthetic Grids and Drains and a Class A Prediction of Track 21
Behaviour
by B. Indraratna, S. Nimbalkar and C. Rujikiatkamjorn
Recent Applications of GRS Technology to Mitigate Natural Disasters in Japan 41
by F. Tatsuoka, M. Tateyama and J. Koseki
Tensile Properties of HDPE Geomembranes with Chemical Solutions Under Exposure to Elevated Temperature 61
by B. A. Khan and H. Y. Jeon
Constitutive Modeling of the Time-Dependent Stress-Strain Behavior of Soils and Applications 69
by J. H. Yin
Development of Transport Infrastructure in Congested Urban Environment 81
by C. F. Leung
Special Lectures
Design Decision Making for Infrastructures Under Restriction of the Energy Consumption 97
by Y. Honjo
Lateral Displacement Induced by Soil-Cement Column Installation 103
by J. C. Chai, T. Hino and D. Wenqi
Geosynthetics Applications: Some Research Studies and Some Case Studies 111
by R. Shivashankar and J. Jayamohan
Design and Performance of Soft Ground Improvement Using PVD with and without Vacuum Consolidation1 123
by P.V. Long, D.T. Bergado, L.V. Nguyen and A.S. Balasubramaniam
A New Cementing Agent From Calcium Carbide Residual and Fly Ash for Soil Stabilization 145
by S. Horpibulsuk and C. Phetchuay
Geotechnical Roles in Landslide Mitigation 151
by S. Soralump
Application of Resistivity Forward and Inverse Analyses to Aid Geophysical Mapping of Burried Utilities in 157
Bangkok Clays
by P. H. Giao
Finite Element Simulations of Vacuum Consolidation with PVD in Bangkok Soft Clay 163
by S. Youwai, P. Tansiri and P. Jongpradist
Effects of Cement Content on Unconfined Compressive Strength of Jamshoro Soil 169
by A. Kumar and G. B. Khaskheli
Why the Tohoku Earthquake Causes Higher Tsunami Wave Runup than the Sumatra Earthquake 177
by A. Siripong
Seismic Design Criteria for Large Embankment Dams of Hydropower Plants 195
by M. Wieland
German Long-Term Experience with Reinforced Motorway Embankments on Soft Soils: A Selected Case Study 205
by D. Alexiew and K. H. Blume
Analysis of Large Deformation of Aquifer Due to Groundwater Pumping in Shanghai 215
by S. L. Shen, L. Ma and Y. S. Xu
Hazard Zone Delineation and Damage Assessment of Debris Flow in Taiwan 219
by D. G. Lin, S. Y. Hsu, W. T. Liu, and K. K. Tien
Case Histories of Damaged and Undamaged Geotechnical Structures During the Great East Japan Disaster 231
by H. Hazarika, T. Hara, T. Ohsumi, M. Yamanaka, H. Furuichi and T. Yamazaki
Compression Behvior of Zinc Contaminated Clayey Soils Treated with Cements 243
by Y. J. Du and M. L. Wei
Theory and Practice of Electric Cone Penetration Test for Clay Ground 251
by T. Koumoto and S. Koslanant
Invited Speakers
Deep Excavation Failures, Can They Be Prevented? 259
by T. L. Gouw
Temperature Effects on the Tensile Strength and Elastic Stiffness of Geogrids 273
by W. Kongkitkul, W. Tabsombut, C. Jaturapitakkul and F. Tatsuoka
The Performance of Strengthening Slope Using Shotcrete and Anchor by Finite Element Method (FEM) 285
by T. Harianto, L. Samang, T. Hino, F. Usman and A. Walenna
Nonlinear Anisotropic Elastic Stiffness of Bangkok Clay 291
by S. Likitlersuang, S. Yimsiri, W. Ratananikom and C. Kingjeep
Green Building for Climate Change 303
by R. Narayan Khare and R. Narayan Khare
Interpretation of Quaternary Research and Countermeasure of Problematic Lime-Based Deep Mixing 307
Solidification in Ariake Sea Coastal Lowlands
by T. Hino, Y. Igaya, J. C. Chai, R. Jia and S. Sueyoshi
Interaction Between Kenaf Geogrid (LLGs) and Compacted Sand by Numerical Simulations 317
by T. Tanchaisawat, D. T. Bergado and S. Artidteang
Impact of Hydrogeological Environment and Land Subsidence Induced by Urbanization in Coastal Mega-cities 323
by Y. S. Xu, S. L. Shen, and J. C. Chai
Geotextile Tubes for Protection of Mangrove Coastlines in Peninsular Malaysia 329
by T.W. Yee, L.K. Lim and Z.Y. Wang
Using Shear Wave Velocity to Determine the Cementation of Soft Bangkok Clay Mixed with Cement 339
by K Piriyakul and T. Gi-nga
Consolidation of Soft Clay Using Composite Vertical Geodrains Through Inward Radial Drainage 343
by M. V. Shah and A. V. Shroff
In Situ Evaluation of Nuclear Density Cone Penetrometer in Marine Sediments 353
by R. Jia, T. Hino, T. Hamada and M. Yoshimura
Migitation of Long-term Settlement of Peat Using Vacuum Preloading 361
by H. Hayashi and S. Nishimoto
Risk Evaluation and Realibilty-Based Design of Earth-fill Dams for Overflow Due to Heavy Rains 367
by S. Nishimura, K. Fujisawa and H. Nagao
Evaluation of Erosion Control Products on Steep Slopes by using Performance and Index Tests 375
by E. Németh, J. Böker, H. Zanzinger, K. Marzini and J. Eppel
Site Characterization of Taytay, Palawan, Philippines Rainfall Triggered Shallow Landslide 383
by C. A. Bacosa
Cumulative Rainfall Departure Approach to Estimate Probability of Landslide as Impact of Climate Change 391
by B. Setiawan, Z. G. Fad and J. Mulia
Behavior of Wall/Embankment with Geogrid and Metallic Reinforcements and Verification of K-Stiffness 401
Working Stress Method
by D.T. Bergado, M. Nualkliang, C.T. Chen and S.S. Lin
Introduction to the Sydney Soil Model 409
by M. D. Liu, J. P. Carter and D. W. Airey
Technical Papers
Flexural Behaviour of the Composite Styrofoam Filled Concrete Beams 429
by R. Djamaluddin and A. M. Akkas
Lateral Resistance of a Single Vertical Pile Installed Near Geogrid-Reinforced Slope 435
by S. M. A. Zomorodian and H. Sadeghi
Infiltration Model Test Using Modification of Rainfall Simulator with Constant Head 445
by H. Arfan and A. Zubair
State of the Long-Term Settlement Behavior of the Metro Tunnel in Shanghai 457
by H. N. Wu, S. L. Shen, and Y. S. Xu
The Absorption Coefficient Characteristics of Makassar City Inundation 459
by J. Patanduk, S. Pongmanda, I. Burhanuddin, and E. Tanggulungan
Construction of Rural Road with Jute Geotextiles - A Case Study 465
by P. K. Choudhury, N. K. Mukherjee and T. Sanyal
Passive Pressure on Retaining Wall with Translational Movement Mode with Backfill of Anisotropic Sand 473
by A. B. Muhiddin and I. Ishibashi
Experimental Study on Interface Shear Behavior Between Sand and Glass Fibre Reinforced Polymer 489
by H. Shaia and H. Abuel-Naga
Mechanical Properties of Soft Clays Lightly Treated by Cement/Lime 497
by N. D. Quang, J. C. Chai, T. Hino, T. Negami
Carbon Footprint of a Polli-Brick Soil Retaining Structure 507
by Y. Xu and J. P. Wang
Model Test of Permeable Geosynthetics Tubes 513
by W. Guo, J. Chu, and S. Yan
Cyclic Deformation Properties of Geomaterials Derived From Recycled Tires 523
by F. Niiya, H. Hazarika, N. Yasufuku and K. Omine
Laboratory Test on Self Healing Capacity of GCL 531
by K. Sari, J. C. Chai, T. Hino and M. Mizuno
Road Management and Road Maintenance 539
by R. M. AlZubaidi
An Apparatus for Specimens Preparation and Testing of Grouted Soil 545
by R. R. Al-Omari, M. S. Al-Soud and A. M. Al-Kinani
Seismic Stability Analysis of Badush Dam 553
by S. A. Khattab and A. A.Khalil
Geochemistry and Tectonic Setting of the Volcanic Rocks of the Ziarat Area, Pakistan 561
by A. Tawab Khan, A. Kilinc, A. M. Kasi, A. S. Khan, D. M. Kakar
Comparison of LWD and PLT for Surface Modulus Evaluation 573
by T. Posribink, W. Kongkitkul, S. Youwai and P. Jongpradist
[-] The following 14 users Like utan's post:14 users Like utan's post
  • isurya, mahyarov, marion33, mary, kuyasipil, sia1, zrilek, lisine, ELAHI1979, 3fan, Jackass, cace-01, Evandrojr, uetian19
