Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive JSSI (Japan Society for Seismic Isolation) standards
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
06-09-2012, 09:44 PM
Please if anyone have access to the following standards , share to CIVILEA Members :
1-Title : Maintenance Standard for Seismically Isolated Buildings - 2010
Explain : JSSI maintenance standard specifies procedures for inspecting seismically isolated buildings, including tentative and periodic inspections, mainly for devices and seismic isolation layers.
2- Title : Design and Construction Manual for Passively Controlled Buildings-2nd Edition
Explain : This manual gives guidelines for design and construction of passively controlled buildings to structural engineers. Control devices are oil dampers, viscous dampers, viscoelastic dampers, hysteretic dampers, and friction dampers.2005
3- Title : Time History Analysis Method for Seismically Isolated Buildings
Explain : Time-history-analysis-method is popular in Japan on design for seismically isolated buildings, and this book gives guide for design and construction of seismically isolated buildings.2005
4- Title : Input Ground Motion for Design on Seismically Isolated Buildings
Explain : This book gives guide on design ground motion by using time-history-analysis-method.2005
5- Title : Performance Evaluation Guideline on Seismically Isolated Buildings
Explain : This book gives guide on performance evaluation for seismically isolated buildings designed or constructed by using time-history-analysis-method.2005
6- Ultimate Performance for Elastomeric Isolators and Friction Factor for Slider and Rotating Ball Bearings
Explain : This book is the results of research for ultimate performance for elastomeric isolators and friction factor for slider and rotating ball bearings on the basis of test data in manufacturers in Japan.2003
Reference Site:
Many Thanks,
[-] The following 3 users Like david-smith's post:3 users Like david-smith's post
  • GROUT, pezhmankhan, malc
 andre85
User ID: 18669
Threads: 29
Likes: 89 in 14 posts
Given Likes: 42
06-11-2012, 03:00 AM
All these documents are in Japanese!
[-] The following 1 user Likes andre85's post:1 user Likes andre85's post
  • david-smith
  [REQUEST] Seismic Isolation of Bridges Using Variable Frequency and Variable Friction Pendulum ali akbar 0 1,240 08-18-2014, 07:13 AM
Last Post: ali akbar
  [REQUEST] Seismic Isolation for Designers and Structural Engineers: hmwere 3 2,953 07-16-2014, 05:24 AM
Last Post: RyanRS
  [REQUEST] Response Control and Seismic Isolation of Buildings haydaroglu 1 1,578 07-19-2013, 09:49 AM
Last Post: fred2010
  [REQUEST] Seismic Isolation Retrofit of a Medical Complex by Integrating Two Large-Scale Buildi david-smith 1 1,671 11-30-2012, 09:59 AM
Last Post: ssobhan
  [REQUEST] Effect of non-proportional damping on seismic isolation 2002 picci4 1 1,598 08-30-2012, 01:48 PM
  [REQUEST] Design and Technical Guideline of Seismic Isolation Structure for Nuclear Power Plant david-smith 0 1,604 06-04-2012, 11:36 AM
Last Post: david-smith
  [REQUEST] Guide Specifications for Seismic Isolation Design 3rd madzaz 1 1,767 02-02-2012, 06:56 AM
Last Post: andre85
