Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Properties of Concrete Using Crushed Brick as Aggregate (paper)
[Request] Properties of Concrete Using Crushed Brick as Aggregate (paper)
05-26-2012, 10:04 PM
Author: Ali A. Akhtaruzzaman and Abdul Hasnat | Size: ?? MB | Format: PDF | Quality: Unspecified | Publisher: Concrete International, Volume: 5, Issue: 02 | Year: February 1, 1983 | pages: 58-63
Abstract:
Four grades of concrete made with crushed brick as aggregate were tested to determine their physical and mechanical properties. Nominal compressive strength ranged from 2000 to 5000 psi (13.8 to 34.5 MPa). Test results compared favorably with those for normal weight concrete as obtained from the ACI code equations. In general, for the same grade of concrete the modulus of elasticity is about 30 percent lower and tensile strength is about 11 percent higher than normal weight concrete. Empirical equations predicting modulus of elasticity and tensile strength of brick aggregate concrete have been derived. Brick aggregate can be used to produce high-grade quality concrete. The unit weight is about 125 to 130 lb per ft3 (2000 to 2080 kg/m3). As the properties of brick aggregate concrete lie between those of normal weight and lightweight concrete, it may be classified as medium weight concrete.
Keywords: aggregates; compressive strength; crushed brick; flexural strength; mix proportioning; modulus of elasticity; splitting tensile strength; tensile strength.
Many thanks to the uploader!
With regards,
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
05-27-2012, 02:32 AM
Grunf et al
Here it is:
[-] The following 5 users Like gulilero's post:5 users Like gulilero's post
  • malc, Jackass, techno, Grunf, Dell_Brett
  [REQUEST] Concrete International Paper essenza 0 1,351 05-26-2014, 04:17 PM
Last Post: essenza
  [REQUEST] Properties of Concrete - by Adam M. Neville Tulanh 1 1,812 10-17-2013, 08:49 AM
Last Post: ak_civil85
  [REQUEST] Brick aggregate concrete davidjmm 0 1,309 04-06-2013, 06:23 PM
Last Post: davidjmm
  [REQUEST] Structural Lightweight Aggregate Concrete Performance foad-7 0 1,334 01-23-2013, 09:45 AM
Last Post: foad-7
  [REQUEST] need paper for experimental test model of 2d concrete moment frame mohamad reza 0 1,412 11-10-2012, 02:22 PM
Last Post: mohamad reza
  [REQUEST] Roman brick and tile Grunf 1 1,534 07-01-2012, 09:44 AM
Last Post: Grunf
  [REQUEST] ASCE paper "Design of Environmental Engineering Concrete Structures ..on Strain..." ynopum 1 1,929 09-19-2011, 09:50 PM
Last Post: cve_jule
