Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] need paper for experimental test model of 2d concrete moment frame
[Request] need paper for experimental test model of 2d concrete moment frame
 mohamad reza
United States
User ID: 39634
Threads: 75
Likes: 20 in 13 posts
Given Likes: 29
11-10-2012, 02:22 PM (This post was last modified: 11-10-2012, 02:23 PM by mohamad reza.)
hello
i need a paper which has examined behavior of sample 2d reinforced concrete moment frame under reverse load and .
i want to use this experimental model for modeling that in seismostruct software and check the experimental and analytical result of that under reverse load .
could you have this kind of paper?please if you have upload here ,
thank you
  [REQUEST] Structural concrete: cracked membrane model ch_surf 1 1,470 06-23-2014, 03:44 PM
Last Post: ssobhan
  [REQUEST] Concrete International Paper essenza 0 1,357 05-26-2014, 04:17 PM
Last Post: essenza
  [REQUEST] Experimental and Analytical Investigation of Partially Prestressed Concrete Beams Str AlmostThere 0 1,250 02-17-2014, 04:35 PM
Last Post: AlmostThere
  [REQUEST] concrete frame two span- two story for thesis? jocker 0 1,266 11-20-2013, 12:28 PM
Last Post: jocker
  [REQUEST] Paper about CPT test brandizzo 0 1,210 07-01-2013, 10:16 AM
Last Post: brandizzo
  [REQUEST] influence of connection modelling on seismic response of moment resisting steel frame DamirDz 1 1,594 03-11-2013, 07:27 AM
Last Post: ssobhan
  [REQUEST] Experimental Investigations on Moment Redistribution and Punching Shear of Flat Plate deviationz 0 1,475 06-05-2012, 06:11 AM
Last Post: deviationz
