Civil Engineering Association eBooks Structural Books Concrete Design Of Reinforced Concrete Foundations
 adshrt
User ID: 8297
Threads: 36
Likes: 1,203 in 114 posts
Given Likes: 364
04-04-2012, 04:22 PM (This post was last modified: 04-04-2012, 04:25 PM by BennyP.)
Author: vARGHESE | Size: 41 MB | Format: PDF | Quality: Unspecified
[Image: 23549566990350605823.jpg]
About The Book
Description:
A companion volume to the author’s Foundation Engineering (published by PHI Learning), this comprehensive and well-organized text deals with the structural design of the commonly used types of reinforced concrete foundations. It explains step-by-step procedure for the design of each type of foundation with the help of a large number of worked-out examples. The book provides an in-depth analysis of topics, such as wall footings, balanced footings, raft foundations, beam and slab rafts, pile caps and pile foundations.
KEY FEATURES
Explains IS Codes on the subject.
Presentation of the book is lecture-based, with each chapter dealing with one topic. This helps the teachers in their lectures.
Deals with modern concepts as well as empirical procedure.
Devotes a separate chapter to the effects of earthquakes on foundations.
 Has a large number of diagrams to illustrate the concepts discussed.
The book is designed as a textbook for the undergraduate and postgraduate students (Structural/Geotechnical) of Civil Engineering. As the book deals with both the fundamentals of the subject and field practice, practising engineers will also find the book very useful.
Contents:
CONTENTS
Preface
Acknowledgements
1. Foundation Structures
2. Review of Limit State Design of Reinforced Concrete
3. IS 456 Provisions for Design of Footings and Pedestals
4. Design of Centrally Loaded Isolated Footings and Column Pedestals
5. Wall Footings
6. Design of Isolated Footings with Vertical Loads and Moments
7. Combined Footings for Two Columns
8. Balanced Footings
9. Strip Footings under Several Columns
10. Raft Foundations
11. Design of Flat Slab Rafts—Mat Foundations
12. Beam and Slab Rafts
13. Compensated Foundations, Cellular Rafts and Basement Floors
14. Combined Piled Raft Foundation (CPRF)
15. Circular and Annular Rafts
16. Under-reamed Pile Foundations
17. Design of Pile Caps
18. Pile Foundations—Design of Large Diameter Socketed Piles
19. Design of Cantilever and Basement Retaining Walls
20. Infilled Virendeel Frame Foundations
21. Steel Column Bases
22. Analysis of Flexible Beams on Elastic Foundation
23. ACI Method for Analysis of Beams and Grids on Elastic Foundations
24. Analysis of Flexible Plates on Elastic Foundations
25. Shells for Foundations
26. Hyperbolic Paraboloid (Hypar) Shell Foundation
27. Design of Conical Shell Foundation
28. Effect of Earthquakes on Foundation Structures
Appendix A Geotechnical Data
Appendix B Extracts from SP 16 for Design of Reinforced Concrete Members
Appendix C Steel Reinforcement Data
Appendix D Design Charts of Centrally Loaded Columns and Footings
Bibliography • Index
[-] The following 75 users Like adshrt's post:75 users Like adshrt's post
  • paitaconst, farahshaheen47, marion33, ykhackhack, chrono146, joker™, karthikeyans3d, mig21, ruaumoko, maad59, rezart, giga, ssobhan, daywalker, Jackass, gulilero, axee1980, jacs127, mgdario, kowheng, isurya, erimajus, triance, malc, knrsa, vvvv, learner20, cace-01, engrezi, reza2011, simanta, lamkin, techno, mary, bhawk0, sodapas, blaze, ibg0203, al_sharis, Quantumm, chenamoy, Dell_Brett, oanm2000, eoby, tattiya, sructme, Hengki, deltalead, igor1234, hignacio43, shadabg, chairatpk, ELAHI1979, ikoleci, versiondemo, pelon2040, oscargon, yutt, TAFATNEB, salahcivil, harsono, Sumatra, ska51, amritarao, Andrew seah, LiviuM, chottabhai, hm20284, narendra, zego2000, darkdkay, Mohammad6299, toa011, bigone, tuanpecc1
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2426
04-05-2012, 01:19 PM
Mirror
No limits to creativity
[-] The following 20 users Like joker™'s post:20 users Like joker™'s post
  • farahshaheen47, ssobhan, blaze, ingchio, rezart, ibg0203, al_sharis, erthqkengnr™, Dell_Brett, seriousboy, cristi, oanm2000, chottabhai, knrsa, lisine, subin91, TAFATNEB, sructme, ska51, bigone
08-16-2012, 07:37 AM
[-] The following 16 users Like shadabg's post:16 users Like shadabg's post
  • isurya, rezart, odiclas, oanm2000, erthqkengnr™, jmromerot, RazvanMelek, TAFATNEB, sructme, simanta, Sumatra, techno, blaze, ska51, hignacio43, bigone
 techno
User ID: 4555
Threads: 95
Likes: 244 in 127 posts
Given Likes: 2286
12-16-2012, 10:28 AM
I found that chapter 14 is missing. Could anyone please reupload/
[-] The following 1 user Likes techno's post:1 user Likes techno's post
  • mig21
 sthane
User ID: 35263
Threads: 0
Likes: 11 in 2 posts
Given Likes: 2
12-16-2012, 12:00 PM
copy and paste from google book.
[email protected]
password
Forallyou
Hope it is useful.
If you think this is not very good, please excuse me.
Thanks
Sthane
 adshrt
User ID: 8297
Threads: 36
Given Likes: 364
12-16-2012, 12:15 PM
[-] The following 9 users Like adshrt's post:9 users Like adshrt's post
  • isurya, techno, blaze, Dell_Brett, ska51, rezart, simanta, Jackass, bigone
 ska51
User ID: 11535
Threads: 427
Likes: 9,406 in 1,251 posts
Given Likes: 4017
12-16-2012, 03:46 PM
Chapter 14 has been incorporated and organized the full book Chapterwise:
Important Comment: The previously uploaded book also contained the "Chapter 14". However, the chapter was located before Chapter 12. It created the confusion.
In this file (mediafire link here), the book has been organized according to Chapter ascending order so that reader can get full advantage from the book. Hope it will help.
"Downstream is Weaker"
[-] The following 45 users Like ska51's post:45 users Like ska51's post
  • ssobhan, Dell_Brett, Trishu999, learner20, seriousboy, cace-01, rezart, gulilero, cashdaily, tomtumx, kowheng, eliseo.as, subin91, malc, oram, eng donny, lisine, cepot, ykhackhack, rendel_©, uetian19, LiviuM, Jackass, dinu69in, shadabg, simanta, tumangik, miquan, tecktik, hm20284, Andrew seah, lednar_ved, darkdkay, Mohammad6299, ting tsai huang, oanm2000, promo8, ersin, narendra, toa011, bigone, pram, harsono, geomahesh, bridgeengineer
 abouferass88
Yemen
User ID: 11928
Threads: 47
Likes: 598 in 75 posts
Given Likes: 237
03-03-2014, 05:17 PM
Mirror Link For Post #7
[-] The following 17 users Like abouferass88's post:17 users Like abouferass88's post
  • vardan, Mohammad6299, Ivan_1980, Dell_Brett, ska51, faros3000, isurya, simanta, carolinandra, Andrew seah, oanm2000, bigone, zrilek, seraneng, bridgeengineer, geomahesh, tuanpecc1
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
03-05-2014, 05:21 AM
Design of Reinforced Concrete Foundations
Author: P. C. Varghese | Size: 94 MB | Format: PDF | Quality: Scanner | Publisher: PHI Learning | Year: 2009 | Pages: 451 | ISBN: 8120336151, 9788120336155
[Image: 65036537747534744440.jpg]
KEY FEATURES
[-] The following 22 users Like Mohammad6299's post:22 users Like Mohammad6299's post
  • shadabg, Dell_Brett, ronnie_150, cristi, ssobhan, Arigato, blaze, oanm2000, versiondemo, bigone, smrutigandh.42, paitaconst, malc, andersen3, avscorreia, ska51, toa011, sructme, Grunf, simanta, dinu69in, moh_towhid
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
07-21-2014, 08:56 AM
[-] The following 10 users Like andersen3's post:10 users Like andersen3's post
  • Mohammad6299, raja, rezart, learner20, PinkPant, eliseo.as, bigone, Dell_Brett, nickycruz, Aviator
  Design and Detailing of Low-Rise Reinforced Concrete Buildings Base on ACI318-14 poolmand 1 3,477 10-14-2024, 07:54 AM
  Reinforced Concrete Design sabooryan 7 7,241 04-29-2024, 05:01 AM
  Design of Reinforced Concrete Silo Groups carolinandra 2 3,943 04-25-2023, 10:31 AM
  Illustrated Design of Reinforced Concrete Buildings (Design of G+3 Storeyed Buildings poolmand 3 4,796 12-29-2022, 06:01 AM
Last Post: amaranu
  Guidelines for the Simplified Design of Structural Reinforced Concrete for Buildings killoobilloo 3 6,171 12-28-2022, 09:55 PM
  CEB: Seismic Design of reinforced concrete structures for controlled inelastic respon lamkin 8 5,888 12-26-2022, 10:50 AM
  Reinforced and prestressed Concrete Design to EC2 - The complete Process gianniorlati 3 3,163 12-20-2022, 08:37 AM
Last Post: Dell_Brett
