Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Probabilistic Seismic Demand Analysis for the Near-Fault Zone (PhD Thesis)
 Sumatra
User ID: 14369
Threads: 103
Likes: 1,925 in 240 posts
Given Likes: 1580
12-27-2011, 04:32 PM
PROBABILISTIC SEISMIC DEMAND ANALYSIS FOR THE NEAR-FAULT ZONE
Author: Reza Sehhati | Size: 4.1 MB | Format: PDF | Publisher: Washington State University | Year: 2008 | pages: 187
Ground motions close to a fault can be significantly influenced by rupture directivity effects. In particular, the effects of forward-directivity may cause severe damage to buildings. These effects have not been clearly addressed in current building codes and engineers still lack specific guidelines as to how to account for forward-directivity effects when determining the seismic hazard for structures. A methodology for probabilistic seismic demand analysis that includes the effects of forward directivity through time domain analysis is proposed in this work. First, the characteristics of forward-directivity ground motions and the structural response to these motions are studied and simplified mathematical representations for pulse-type forward-directivity ground motions are proposed. Intensity Measures for forward directivity ground motions are then proposed based on the simplified pulses. For this purpose, the non-linear dynamic response of three generic multi-story shear buildings to near-fault and ordinary ground motion ensembles was studied using Incremental Dynamic Analysis. Results show that whenever the pulse period of forward-directivity ground motions is close to the first-mode structural period, structural response is controlled by forward-directivity pulses. For these cases, structural response can be predicted using pulse-period and pulse-amplitude as intensity measures.
The principles of Probabilistic Seismic Demand Analysis are then extended to consider the effect of forward-directivity within a probabilistic framework. Structural response to pulse-type forward-directivity ground motions is quantified by means of time-domain analysis of simplified pulses that comprehensively represent all possible pulse-type ground motion scenarios. The hazard due to pulse-type motions is then coupled with conventional spectral domain seismic demand analyses for non-pulse-type ground motions. Results show that the proposed methodology captures more accurately the structural response to pulse-type ground motions than with current methods leading to the prediction of greater hazard for near-fault scenarios. In addition, the proposed method provides a clear guide for the selection of time histories for the design of near-fault structures.
[-] The following 8 users Like Sumatra's post:8 users Like Sumatra's post
  • blaze, kowheng, Jackass, malc, Dell_Brett, mgdario, yantonegr, ibmarin
  An Introduction to Probabilistic Seismic Hazard Analysis Sumatra 1 2,764 05-11-2019, 03:35 AM
  Selected Topics in Probabilistic Seismic Hazard Analysis pezhmankhan 3 3,372 05-05-2019, 02:17 AM
  fib B68 - Probabilistic Performance-Based Seismic Design xnr09 2 2,344 07-24-2017, 07:20 AM
Last Post: xnr09
  Probabilistic Methods for Seismic Assessment of Existing Structures ir_71 1 2,408 09-09-2016, 10:09 AM
Last Post: ssobhan
  Near-Fault Seismic Ground Motions amott 2 2,686 11-23-2014, 06:27 AM
Last Post: sinamaleki
  Structural Dynamics and Probabilistic Analysis for Engineers babak 3 3,403 07-13-2014, 09:07 PM
Last Post: cace-01
  Recommendations for Probabilistic Seismic Hazard Analysis: Guidance on Uncertainty hazus 0 1,622 07-27-2011, 10:01 AM
Last Post: hazus
