Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN ISO 11058:2010 Geotextiles and geotextile-related products
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
12-26-2011, 01:03 AM
BS EN ISO 11058:2010 Geotextiles and geotextile-related products. Determination of water permeability characteristics normal to the plane, without load
Size: 650 KB | Format: PDF | Publisher: BSI | Year: 31 May 2010 | pages: 24 | ISBN: 978 0 580 67999 5
[Image: 76584191158172581879.png]
BS EN ISO 11058 specifies two test methods for determining the water permeability characteristics of a single layer of geotextile or geotextile-related product normal to the plane:
a) The constant head method;
b) The falling head method.
If the full permeability characteristics of the geotextile or geotextile-related product have previously been established, then for control purposes it can be sufficient to determine the velocity index at a head loss of 50 mm only.
Contents of BS EN ISO 11058:
Foreword
1 Scope
2 Normative references
3 Terms and definitions
4 Test specimens
4.1 Handling
4.2 Selection
4.3 Number and dimensions
4.4 Condition of specimens
5 Constant head method
5.1 Principle
5.2 Apparatus
5.3 Procedure
5.4 Calculation and expression of results
6 Falling head method
6.1 Principle
6.2 Apparatus
6.3 Procedure
6.4 Calculation and expression of results
7 Test report
Annex A (informative) Determination of the correction factor, RT, to a water temperature of 20 °C
Annex B (informative) Relationship between head loss and flow velocity
Annex C (informative) Velocity index
Annex D (informative) Experimental data and calculations
[-] The following 8 users Like mybest's post:8 users Like mybest's post
  • kowheng, utan, Jackass, vpmohammed, ir_71, kvtasp, peixoto, Dell_Brett
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
12-29-2011, 03:01 AM
[-] The following 1 user Likes kvtasp's post:1 user Likes kvtasp's post
  • blaze
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
02-22-2013, 07:44 AM
  BS EN ISO 12958:2010 Geotextiles and geotextile-related products mybest 2 2,153 02-22-2013, 07:34 AM
Last Post: arshiakh
  BS EN ISO 12956:2010 Geotextiles and geotextile-related products mybest 2 2,088 02-22-2013, 07:30 AM
Last Post: arshiakh
  BS EN 13170:2008 Thermal insulation products for buildings - Factory made products of ir_71 0 1,706 12-26-2011, 09:06 AM
  BS EN 13164:2008 Thermal insulation products for buildings - Factory made products of ir_71 0 1,731 12-25-2011, 05:08 PM
