Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 13164:2008 Thermal insulation products for buildings - Factory made products of
12-25-2011, 05:08 PM
EN 13164:2008 Thermal insulation products for buildings - Factory made products of extruded polystyrene foam (XPS) - Specification
Author: Technical Committee CEN/TC 88 | Size: 0.24 MB | Format: PDF | Publisher: CEN | Year: 2008 | pages: 42
[Image: 49371748003155964374.jpg]
This European Standard specifies the requirements for factory made products of extruded polystyrene foam,
with or without facings or coatings, which are used for thermal insulation of buildings. The products are
manufactured in the form of boards, which are also available with special edge and surface treatment
(tongue and grooves, shiplap, etc.).
This European Standard specifies product characteristics and includes procedures for testing, evaluation of
conformity, marking and labelling.
Products covered by this European Standard are also used in prefabricated thermal insulating systems and
composite panels; the performance of systems incorporating these products is not covered. This European
Standard also covers multilayered insulation boards.
This European Standard does not specify the required level of a given property to be achieved by a product to
demonstrate fitness for purpose in a particular application. The levels required for a given application are to be
found in regulations or non-conflicting standards.
Products with a declared thermal resistance lower than 0,25 m2⋅K/W or a declared thermal conductivity
greater than 0,060 W/(m⋅K) at 10 °C are not covered by this European Standard.
This European Standard does not cover in situ insulation products and products intended to be used for the
insulation of building equipment and industrial installations or products intended for acoustic insulation.
  • Jackass, Dell_Brett, kowheng, malc, peixoto
  BS EN 14629:2007 Products and systems for the protection and repair of concrete structures ir_71 2 3,227 02-11-2022, 09:56 AM
Last Post: CAMSECT
  BS EN 12190:1999 Products and systems for the protection and repair of concrete struc ir_71 2 2,821 11-27-2019, 06:48 AM
  BS 7543:2003 Guide to durability of buildings and building elements, products and ir_71 2 2,825 03-13-2018, 11:22 AM
  BS EN 1170-5:Precast concrete products. Test method for glass-fibre reinforced cement yakwetu 2 2,241 04-27-2016, 02:02 PM
Last Post: abualamal
  BS EN 752:2008 Drain and sewer systems outside buildings ir_71 4 4,907 08-19-2015, 04:59 AM
Last Post: concreteok
  BS EN 12794:2005-Precast concrete products. Foundation piles PinkPant 0 1,675 06-05-2015, 11:29 AM
Last Post: PinkPant
  BS EN 1168:2005 Precast concrete products — Hollow core slabs ir_71 6 5,104 03-09-2015, 03:46 PM
Last Post: Veggeta
