Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 12620:2002/AC Aggregates for concrete
06-28-2011, 01:11 PM
Author: CEN/TC 154 | Size: 0.33 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 49
[Image: 45495875938973012973.jpg]
This European Standard specifies the properties of aggregates and filler aggregates obtained by processing natural, manufactured or recycled materials and mixtures of these aggregates for use in concrete. It covers aggregates having an oven dried particle density greater than 2,00 Mg/m3 (2 000 kg/m3) for all concrete, including concrete in conformity with EN 206-1 and concrete used in roads and other pavements and for use in precast concrete products. It also specifies that a quality control system is in place for use in factory production control and it provides for the evaluation of conformity of the products to this European Standard. This standard does not cover filler aggregates to be used as a constituent in cement or as other than inert filler aggregates for concrete.
  • kowheng, meekaaku, blaze, Jackass, zrilek, toa011, warbeast, Grunf, Trishu999, concreteok, sivlad, Dell_Brett, vvvv
 piromoplus
Member
User ID: 25518
Threads: 11
Likes: 16 in 8 posts
Given Likes: 12
06-01-2013, 06:52 AM (This post was last modified: 06-01-2013, 07:07 AM by piromoplus.)
All links are dead:(
find new link:
[-] The following 3 users Like piromoplus's post:3 users Like piromoplus's post
  • Dell_Brett, narendra, vvvv
11-06-2014, 06:31 PM
EN 12620:2002+A1:2008 Aggregates for concrete
Author: Technical Committee CEN/TC 154 | Size: 0.9 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2008 | pages: 56 | ISBN: 9780580633270
[Image: 96943191558374910680.jpg]
This European Standard specifies the properties of aggregates and filler aggregates obtained by processing natural, manufactured or recycled materials and mixtures of these aggregates for use in concrete. It covers aggregates having an oven dried particle density greater than 2,00 Mg/m3 (2 000 kg/m3) for all concrete, including concrete in conformity with EN 206-1 and concrete used in roads and other pavements and for use in precast concrete products. It also covers recycled aggregate with densities between 1,50 Mg/m3 (1 500 kg/m3) and 2,00 Mg/m3 (2 000 kg/m3) with appropriate caveats and recycled fine aggregate (4 mm) with appropriate caveats." It also specifies that a quality control system is in place for use in factory production control and it provides for the evaluation of conformity of the products to this European Standard. This standard does not cover filler aggregates to be used as a constituent in cement or as other than inert filler aggregates for concrete.
NOTE 1 Aggregates used in construction should comply with all the requirements of this European Standard. As well as familiar and traditional natural and manufactured aggregates Mandate M/125 "Aggregates" included recycled aggregates and some materials from new or unfamiliar sources. Recycled aggregates are included in the standards and new test methods for them are at an advanced stage of preparation. For unfamiliar materials from secondary sources, however, the work on standardisation has only started recently and more time is needed to define clearly the origins and characteristics of these materials. In the meantime such unfamiliar materials when placed on the market as aggregates must comply fully with this standard and national regulations for dangerous substances (see Annex ZA of the standard) depending upon their intended use. Additional characteristics and requirements may be specified on a case by case basis depending upon experience of use of the product, and defined in specific co
  • Mohammad6299, allagui10, oanm2000, malc, Andrew seah, aslam, zrilek, PinkPant, blaze, lisine, st77bel, Dell_Brett, peixoto
02-22-2019, 12:11 PM
Size: 345 KB | Format: PDF
[-] The following 8 users Like kowheng's post:8 users Like kowheng's post
  • lisine, Grunf, PinkPant, Nita1391, Aviator, oanm2000, Dell_Brett, concreteok
  EN 13043:2002/AC Aggregates for bituminous mixtures and surface treatments for roads, ir_71 2 2,800 09-02-2014, 07:58 PM
Last Post: vangjo
  EN 1917:2002 + AC:2006 Concrete manholes and inspection chambers, unreinforced, steel ir_71 0 2,022 12-14-2010, 05:47 PM
