Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 1917:2002 + AC:2006 Concrete manholes and inspection chambers, unreinforced, steel
12-14-2010, 05:47 PM
EN 1917:2002 + AC:2006 Concrete manholes and inspection chambers, unreinforced, steel fibre and reinforced
Author: CEN/TC 165 | Size: 1 MB | Format: PDF | Publisher: CEN | Year: 2002 & 2006 | pages: 105
[Image: 23138373929994458580.jpg]
This European Standard specifies performance requirements as defined in Table 1 and describes test methods for
precast concrete units for inspection chambers designed to be used for inverts not exceeding 2 metres deep and
manholes, of circular, rectangular (with or without chamfered or rounded corners) or elliptical internal shape,
unreinforced, steel fibre and reinforced, with nominal sizes and normal length not exceeding DN 1 250 (circular) or
LN 1 250 (rectangular or elliptical). The intended use is to permit access to, and to allow aeration of, drain or sewer
systems for the conveyance of sewage, rainwater and surface water under gravity or occasionally at low head of
pressure, mainly installed in areas subjected to vehicular and/or pedestrian traffic. Requirements for joints
(elastomeric, plastomeric or other sealing materials, either integrated in the unit or supplied separately) are also
specified.
Provision is made for the evaluation of conformity of units to this European Standard.
Marking conditions are included.
  • rezart, usman, ruaumoko, dinu69in, kowheng, toa011, salahcivil, k1k0k0, roaming79, kaci, dbsimon29, blaze, st77bel
  EN 1916 Concrete pipes and fittings, unreinforced, steel fibre and reinforced datagap 4 5,105 02-13-2022, 11:44 AM
  EN 12620:2002/AC Aggregates for concrete ir_71 3 3,750 02-22-2019, 12:11 PM
  EN 10168:2004 Steel products - Inspection documents - List of information and descrip ir_71 0 2,133 01-23-2011, 07:37 AM
