Civil Engineering Association eBooks Structural Books Analysis & Design SCI P287: Design of Composite Beams using Precast Concrete Slabs
04-15-2011, 06:10 PM
Author: S J Hicks, R M Lawson | Size: 1.86 MB | Format: PDF | Publisher: SCI | Year: 2003 | pages: 101 | ISBN: 1859421393
[Image: 37210182758783507213.jpg]
This publication provides guidance on the design of steel beams acting compositely with precast concrete slabs in multi-storey buildings. The use of hollow core or solid plank precast units offer benefits in terms of cost (the long spanning capabilities of the precast slabs lead to fewer secondary beams) as well as the advantages offered by composite construction. The design basis is generally in accordance with BS 5950-3, supplemented by recommendations from Eurocode 4 and data from tests. Particular issues affecting the use of precast concrete concern the requirements of effective shear connection and transverse reinforcement. Small-scale push-out tests, and earlier composite beam tests, have established reduction factors for the design resistance of welded shear connectors as a function of the gap between the ends of the precast concrete units, and the amount of transverse reinforcement provided.
The guidance also emphasises the importance of the design of the steel beam in the non-composite construction stage, where out-of-balance loads can occur during installation of the precast concrete units. The guidance applies to hollow core units of 150 to 260 mm depth, and to solid precast planks. A step-by-step design procedure is given for composite beams using various forms of precast concrete units, with or without a concrete topping. This is supplemented by a fully worked design example for a composite beam in a 15.8 m × 7.2 m grid, and a series of design tables for concept design.
[-] The following 34 users Like ir_71's post:34 users Like ir_71's post
  • oanm2000, malc, chrono146, ikoleci, nowanda, toa011, Nilupa, miquan, kowheng, jferrer, lamkin, tluc, almadar12, knrsa, seriousboy, sheb101, nuttapolk, zrilek, cristi, draluka, monter, tazmania, ajmf77, iluso81, simanta, gulilero, slowet, Grunf, klsamy77, Jackass, ykhackhack, ibg0203, bigone, tuanpecc1
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
11-16-2012, 10:39 AM
all links dead; direct link
  • cace-01, Dell_Brett, ykhackhack, subin91, chenamoy, bigone
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
04-25-2018, 10:26 PM
[-] The following 13 users Like gulilero's post:13 users Like gulilero's post
  • cace-01, milova, vvvv, zrilek, tuanpecc1, febo927, Andrew seah, jcbv, oanm2000, Aviator, PinkPant, carolinandra, mgdario
  Composite Structures of Steel and Concrete: Beams, Slabs, Columns, Frames Flexi 19 32,389 01-26-2022, 04:45 AM
Last Post: Veggeta
  Tall building design: steel, concrete, and composite systems asim99 3 8,719 12-23-2021, 01:10 PM
Last Post: babakfeyzi
  Concrete Beams with Openings: Analysis and Design struceng 13 19,050 01-13-2016, 01:19 AM
Last Post: ibg0203
  Optimal Design of Flexural Systems: Beams, Grillages, Slabs, Plates and Shells apocalipse 1 5,375 01-11-2015, 10:12 PM
Last Post: Veggeta
  SCI P300: Composite Slabs and Beams using Steel Decking ir_71 3 8,378 02-19-2014, 08:30 AM
Last Post: vinnunsam
  SCI Design of Composite Slabs and Beams with Steel Decking ir_71 5 10,917 04-09-2013, 06:34 AM
Last Post: pezhmankhan
