Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] ASTM Journal: Effects of Non-Plastic Fines on Minimum and Maximum Void Ratios of Sand
[Request] ASTM Journal: Effects of Non-Plastic Fines on Minimum and Maximum Void Ratios of Sand
 sia1
User ID: 2076
Threads: 14
Likes: 117 in 15 posts
Given Likes: 117
04-11-2011, 03:56 AM (This post was last modified: 04-11-2011, 02:55 PM by usman.)
dear user
i need this paper
thanks
ade, PV
Professor and graduate student, The Johns Hopkins University, Baltimore,MD
Liggio, CD
Yamamuro, JA
Assistant professor, Clarkson University, Potsdam,NY
Abstract
The behavior of sand is affected by the content of nonplastic fine particles. How and to what degree the fines content affects the minimum and maximum void ratios has been studied in detail. A review is presented of previous theoretical and experimental studies of minimum and maximum void ratios of single spherical grains, packings of spheres of several discrete sizes, as well as optimum grain-size ratios to produce maximum densities. A systematic experimental study is performed of the variation of minimum and maximum void ratios with contents of fines for sands with smoothly varying particle size curves and a large variety of size distributions. It is shown that the fines content plays an important role in determining the sand structure and the consequent minimum and maximum void ratios. It is indicated how the fines content and sand structure affects the compressibility and the static liquefaction potential of the sand.
compressibility, fines content, laboratory test, liquefaction, relative density, sands, size distribution, void ratio
Paper ID: GTJ11373J
DOI: 10.1520/GTJ11373J
[-] The following 1 user Likes sia1's post:1 user Likes sia1's post
  • sasan7351
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
04-12-2011, 06:07 PM
here
PHP Code:
http://ifile.it/xp81ztj
[-] The following 2 users Like hich's post:2 users Like hich's post
  • sia1, sasan7351
  [REQUEST] Geotechnical Testing Journal (ASTM) maxpn3 0 1,552 05-28-2013, 03:53 AM
Last Post: maxpn3
  [REQUEST] Seismic Evaluation of Column-to-Beam Strength Ratios in Reinforced Concrete Frames mohamad reza 1 1,596 02-04-2013, 11:08 AM
Last Post: ssobhan
  [REQUEST] ASTM C1107 & a paper from ASTM journal hessi 1 1,604 10-09-2012, 12:10 PM
Last Post: EngineerGeek
  [REQUEST] Comparison of Methods for Computing Equivalent Viscous Damping Ratios of Structures 3fan 1 1,774 02-16-2012, 08:55 AM
  [REQUEST] ASTM D4318-10, D1586-11, D2166-06, ASTM D2850 - 03a(2007) mybest 1 1,547 02-14-2012, 12:13 PM
Last Post: portal61
  [REQUEST] Geotechnical Testing Journal, ASTM, Vol.16 No.1, March 1993 wobmot 1 1,683 01-26-2012, 02:49 PM
Last Post: mybest
  [REQUEST] Post-Yield Behavior of Reinforced Concrete Membrane Elements—The Hsu/Zhu Ratios junaid 0 1,429 10-11-2011, 11:33 AM
Last Post: junaid
