Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Comparison of Methods for Computing Equivalent Viscous Damping Ratios of Structures
[Request] Comparison of Methods for Computing Equivalent Viscous Damping Ratios of Structures
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
02-15-2012, 09:47 PM (This post was last modified: 02-15-2012, 09:47 PM by 3fan.)
of Structures with Added Viscous Damping
Journal of Structural Engineering / Volume 134 / Issue 1
Submitted 22 February 2005; accepted 13 April 2006
Authors : Finley A. Charney, Ph.D., P.E.1 and Robert J. McNamara, S.E.2
Abstract:
Three analysis methods are compared for determining the equivalent viscous damping ratios in a simple one-story, one-bay system with three different added damping configurations. The analysis methods are modal strain energy using the undamped mode shapes, free vibration log decrement, and complex eigenvalue-eigenvector analysis. The damping configurations include a diagonal configuration, a horizontal configuration, and a toggle-braced system. For each of these systems, a variety of linkage stiffness and damper capacities are considered. In all cases the structure, exclusive of the dampers, is assumed to remain elastic. A brief discussion is provided for the behavior of systems with nonlinear viscous dampers. The results of the study show that significantly different values may be obtained for the effective viscous damping in the same system when different analysis approaches are used. For the toggle-braced system with relatively flexible linkages, it was shown that the modal strain energy approach consistently produced increasing effective damping with increased damper capacity, while the other two methods indicated the opposite results. Subsequent analysis of the toggle-braced structure using the complex eigenvalue-eigenvector approach showed that the effective system damping was indeed decreasing with an increased device damping constant, and that the behavior could be attributed to the axial flexibility of the toggle brace linkage. The analysis indicated that the greater the flexibility of the linkage relative to the damping constant of the device, the greater the phase difference between the deformational velocity in the device and the relative horizontal velocity of the story containing the device. While the phase shift is evident from response history analysis, the most efficient visualization tool is a plot of the damped mode shapes on a complex plane.
Thanks in advance,
3fan
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
02-16-2012, 08:55 AM
[-] The following 11 users Like lisine's post:11 users Like lisine's post
  • kowheng, Grunf, atram, Sumatra, ting tsai huang, 3fan, gulilero, Dell_Brett, malc, tluc, zrilek
  [REQUEST] A comparison of numerical methods for multi-tied walls ch_surf 1 1,512 07-17-2014, 10:27 PM
Last Post: ssobhan
  [REQUEST] Comparison of Nonlinear Static Methods for the Seismic Assessment of Plan Irregular F mohamad reza 0 1,230 04-09-2013, 08:46 AM
Last Post: mohamad reza
  [REQUEST] Seismic Evaluation of Column-to-Beam Strength Ratios in Reinforced Concrete Frames mohamad reza 1 1,578 02-04-2013, 11:08 AM
Last Post: ssobhan
  [REQUEST] Experimental Verification of Viscous Damping Modeling for ITHA Grunf 2 1,800 06-29-2012, 09:36 PM
Last Post: amir201
  [REQUEST] Journal of Sound and Vibration - Equivalent viscous damping 3fan 4 2,610 05-15-2012, 02:27 PM
  [REQUEST] Paper: Static pushover methods explanation comparison and implementation netsonicyxf 1 1,703 03-22-2012, 05:19 PM
Last Post: mehabb
  [REQUEST] Post-Yield Behavior of Reinforced Concrete Membrane Elements—The Hsu/Zhu Ratios junaid 0 1,415 10-11-2011, 11:33 AM
Last Post: junaid
