Civil Engineering Association Software Software Product Autodesk Products Autodesk DirectConnect for UG NX 2012 (x86/x64)
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
03-30-2011, 07:33 PM
Autodesk DirectConnect software is a product to transfer data from applications for industrial design in CAD.
The result of the transfer of data using Autodesk DirectConnect is a continuous process of design, which eliminates the need to develop, saves time and preserves the original concept designer. Autodesk DirectConnect log files allow you to add filters to the import scripts that depending on the layers and materials to filter out unwanted geometry.
To transfer data to Autodesk products for industrial design (AutoCAD and Autodesk Inventor) using a commercial version of DirectConnect is not required. However, imports in these applications requires an installed program DirectConnect.
Product Key:
719D1
[Image: 66941105988152076716.jpg]
  • rezart, niki102, warbeast, sasan7351
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
04-01-2011, 05:48 AM
Other links:
  • Grunf
 niki102
User ID: 8143
Threads: 85
Likes: 2,495 in 189 posts
Given Likes: 845
04-21-2011, 08:58 PM
[SINGLE FILE LINK]
Autodesk DirectConnect for UG NX 2012 32bit & 64bit | 1.0 Gb
[-] The following 1 user Likes niki102's post:1 user Likes niki102's post
  • warbeast
  Autodesk Products 2012 x-force keygen for x32 systems BennyP 7 17,815 03-07-2025, 10:37 AM
  Autodesk AutoCAD Plant3D 2012 (x86/x64) BennyP 6 11,139 01-17-2013, 05:47 PM
  Autodesk AutoCAD LT 2012 x32 x64 ISO BennyP 12 19,773 12-17-2012, 03:32 PM
  Autodesk Subscription 2012 MegaPack BennyP 9 16,768 03-18-2012, 08:36 PM
Last Post: oasis_tree
  Autodesk AutoCAD Structural Detailing 2012 x32 x64 BennyP 18 31,335 03-01-2012, 02:19 PM
  Autodesk Inventor Standard and Professional 2012 (x86 x64) BennyP 10 16,029 02-24-2012, 07:05 PM
  Autodesk Subassembly Composer For Civil3D 2011 2012 32bit & 64bit BennyP 2 7,943 02-21-2012, 12:02 AM
Last Post: joinsms
