Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Guide to Retaining Wall Design
03-12-2011, 08:47 AM
Size: 5.04 MB | Format: PDF | pages: 155
[Image: 30446370894428038659.jpg]
This Guide to Retaining Wall Design is the first Guide to be produced by the Geotechnical Control Office. It will be found useful to those engaged upon the design and construction of retaining walls and other earth retaining structures in Hong Kong and, to a lesser extent, elsewhere. This Guide should best be read in conjunction with the Geotechnical Manual for Slopes (Geotechnical Control Office, 1979), to which extensive reference is made. The Guide has been modelled largely on the Retaining Wall Design Notes published by the Ministry of Works and Development, New Zealand (1973), and the extensive use of that document is acknowledged. Many parts of that document, however, have been considerably revised and modified to make them more specifically applicable to Hong Kong conditions. In this regard, it should be noted that the emphasis in the Guide is on design methods which are appropriate to the residual soils prevalent in Hong Kong. Many staff members of the Geotechnical Control Office have contributed in some way to the preparation of this Guide, but the main contributions were made by Mr. J.C. Rutledge, Mr. J.C. Shelton, and Mr. G.E. Powell. Responsibility for the statements made in this document, however, lie with the Geotechnical Control Office.
[-] The following 69 users Like ir_71's post:69 users Like ir_71's post
  • melkat, techno, usman, kowheng, theanhpe, Hengki, vvvv, malc, seriousboy, utan, blaze, deadlord, haytham, Dell_Brett, Evandrojr, maad59, dbsimon29, rezart, sujups, cordoba123, kerenski_t, chenamoy, hapsea, jcoronellr, dinu69in, OSHO, tamboon, axcel, SR71, ELAHI1979, oanm2000, igor1234, DamaD, Clouseau, shaqee, TAFATNEB, erthqkengnr™, eliseo.as, cve_jule, versiondemo, simanta, strengr, jfjdm, zainseiya, cigutierrezg, lasalleguy, ArissB, we_mbm, zrilek, Ivan_1980, civilphongvan, Mohoh77, vinnunsam, sashka.od, ruaumoko, julioreptil, cristi, monter, kevin8107, Nilupa, chairatpk, pm81, peymanlord, shadabg, gacella, triance, pmg814, PinkPant, tuanpecc1
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
03-13-2011, 09:50 PM
Direct link:
[-] The following 14 users Like ssobhan's post:14 users Like ssobhan's post
  • usman, Dell_Brett, strengr, zainseiya, kowheng, concreteok, zrilek, 3fan, tang1942, oanm2000, monter, Nilupa, peymanlord, shadabg
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
03-14-2011, 03:02 PM
Mirror links
[-] The following 13 users Like 3fan's post:13 users Like 3fan's post
  • kowheng, fashion, Dell_Brett, gacella, cigutierrezg, usman, zrilek, oanm2000, Nilupa, pm81, GMianG, shadabg, lisine
09-03-2012, 10:53 AM
[-] The following 10 users Like shadabg's post:10 users Like shadabg's post
  • stosto6666, lednar_ved, blaze, subin91, 3fan, Jackass, SCREAM7890, Andrew seah, triance, salahcivil
 Ernest0
Nicaragua
User ID: 15083
Threads: 39
Likes: 1,155 in 60 posts
Given Likes: 204
10-16-2012, 09:15 PM
Guide to Retaining Wall Design 2ed
Size: 7.28 MB | Format: PDF | Quality: Scanner
[Image: 35842467474218791238.jpg]
This Geoguide presents a recommended standard of good practice for the design of retaining walls in Hong Kong. The first edition of the Gwguide was published in July 1982 and preparation for a second edition begun in 1985 with a consultation exercise to obtain the views of practitioners on the first edition. Work on the revision began in 1987.
The Geoguide covers the types of retaining walls which are commonplace in Hong Kong, including conventional reinforced concrete walls, gravity walls such as crib walls, gabion walls and mass concrete walls, and cantilevered retaining walls. It does not aim to deal comprehensively with maritime structures nor structures used to support the sides of deep excavations, such as sheet pile walls.
[-] The following 15 users Like Ernest0's post:15 users Like Ernest0's post
  • paitaconst, techno, Evandrojr, gulilero, kowheng, andersen3, zrilek, lisine, daywalker, nickycruz, simanta, narendra, inge911, malc, tuanpecc1
  Basics of Retaining Wall Design - by Hugh Brooks OSHO 15 16,305 11-30-2024, 10:56 AM
Last Post: civilfafa
  Guidance on embedded retaining wall design (CIRIA C760) jacs1976 1 3,750 10-27-2021, 03:07 AM
Last Post: concreteok
  How to Build a Reinforced Besser Block Retaining Wall joker™ 1 3,246 09-06-2012, 05:09 AM
Last Post: shadabg
  Foundation Analysis and Design: 1. Mat Foundations, 2. Retaining Walls aidil01 4 4,544 01-29-2012, 09:16 AM
Last Post: joker™
  Moments & Reactions for Rectangular Plates (design of Counterfort Retaining wall) vsa2010 0 2,736 08-06-2011, 05:53 AM
Last Post: vsa2010
