Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) MONITORING STEEL GIRDER STABILITY GOR SAFER BRIDGE ERECTION
 mowafi3m
Egypt
User ID: 1236
Threads: 384
Likes: 9,312 in 675 posts
Given Likes: 1663
02-22-2011, 09:56 PM
[Image: 36623990196575323497.jpg]
SUMMARY
The stability of steel plate girders during erection should be given special attention because the lateral support on the compression flange might temporarily not be present. Rules of thumb have been adopted by contractors to check the stability of cantilever or simply supported girders under erection using the maximum L (unbraced length) over b (compression flange width) ratio, beyond which lateral torsional buckling failure would occur under the girder’s self-weight. In order to check the rules of thumb, closed-form equations for the maximum L/b ratios of cantilevers and simply supported girders were developed following the current AASHTO LRFD code, and parametric studies were conducted for various girder sections. Finite element analyses (FEA) were conducted on a girder section for both the cantilever and the simply supported case to further understand the lateral-torsional buckling behavior of the girder under self-weight and identify the maximum L/b ratio through a trail-and-error approach, as well as verify that bracing the top tension flange at the cantilever free end would be more effective to prevent lateral torsional buckling than bracing the bottom compression flange.
873KB,12 Pages
[-] The following 6 users Like mowafi3m's post:6 users Like mowafi3m's post
  • kowheng, blaze, oanm2000, zrilek, tremonti, ladjin
  FRP Deck and Steel Girder Bridge Systems ir_71 4 3,544 09-25-2018, 01:01 PM
Last Post: febo927
  Some Research Results on Bridge Health Monitoring, Maintenance and Safety III ssobhan 0 1,617 07-12-2014, 09:52 AM
Last Post: ssobhan
  AASHTO - Guide Specifications for Horizontally Curved Steel Girder Highway Bridges chrono146 1 2,813 07-02-2014, 03:35 PM
Last Post: i_kabir
  Bridge Maintenance, Safety Management, Health Monitoring and Informatics abudabeeja 4 3,835 03-01-2013, 04:24 PM
Last Post: arshiakh
  Monitoring and Load Distribution Study for the Land Bridge mahyarov 0 1,356 10-30-2012, 08:40 AM
Last Post: mahyarov
  Long-term Maintenance Monitoring Demonstration on a Movable Bridge mahyarov 0 1,371 10-29-2012, 07:13 AM
Last Post: mahyarov
  Health Monitoring of Precast Bridge Deck Panels Reinforced with Glass Fiber Reinforce mahyarov 0 1,461 10-29-2012, 06:37 AM
Last Post: mahyarov
