Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 7668:2004 Weldable structural steels — Hot finished structural hollow sections in
02-02-2011, 12:19 PM
BS 7668:2004 Weldable structural steels — Hot finished structural hollow sections in weather resistant steels — Specification
Author: Committee ISE/12 | Size: 0.3 MB | Format: PDF | Publisher: BSI | Year: 2004 | pages: 18 | ISBN: 0580434451
[Image: 52545020081982319528.jpg]
This British Standard specifies the technical delivery requirements for weldable weather resistant steels for general structural and engineering purposes in the form of hot finished hollow sections of circular, square or rectangular form. It also applies to hollow sections formed hot with or without subsequent heat treatment or formed cold with subsequent heat treatment to obtain equivalent metallurgical conditions to those obtained in the hot formed product. However, in the case of hollow sections formed from plate and with the seams metal arc welded, this standard covers only the requirements for the plate material. The products are equally suitable for bolted and riveted structures. The products specified in this British Standard are intended for use in construction. Requirements for tolerances, dimensions and sectional properties are specified in BS EN 10210-2.
NOTE Two material grades are specified in this standard and the user should select the grade appropriate to the intended use and service conditions. The grades and mechanical properties are compatible with those in BS EN 10155.
This British Standard does not apply to products covered by BS EN 10025, BS EN 10113 (all parts), BS EN 10155, BS EN 10210-1, BS EN 10219-1, BS EN 10219-2 and BS EN 10225.
In addition to the definitive requirements, this standard also requires the items detailed in Clause 4 to be documented. For compliance with this standard, both the definitive requirements and the documented items have to be satisfied.
  • Dell_Brett, toa011, kowheng, Grunf, usman, oanm2000, zrilek, peixoto, asim99
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
02-18-2013, 12:19 PM
link dead; reposted here:
pass:
[-] The following 4 users Like andersen3's post:4 users Like andersen3's post
  • malc, knrsa, Dell_Brett, asim99
  BS EN 10219:2006 Cold formed welded structural hollow sections of non-alloy and fine ir_71 4 4,253 06-03-2019, 09:56 AM
Last Post: concreteok
  BS 4449:2005+A2:2009 Steel for the reinforcement of concrete — Weldable reinfor... portal61 4 4,113 09-16-2014, 12:20 PM
  BS 644:2009 Timber windows. Fully finished factory-assembled windows of various types mybest 2 2,258 02-25-2013, 07:12 AM
Last Post: arshiakh
  BS EN 10034:1993 Structural steel I and H sections - Tolerances on shape and dimensio ir_71 1 3,184 02-14-2013, 11:02 AM
  BS 4360 : 1990 - Weldable Structural Steel rohailiyaz 0 1,999 04-14-2011, 06:51 AM
Last Post: rohailiyaz
