Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 7608:1993 Code of practice for fatigue design and assessment of steel structures
02-02-2011, 10:14 AM
Author: Committee WEE/37 | Size: 0.75 MB | Format: PDF | Publisher: BSI | Year: 1999 | pages: 88 | ISBN: 0580212815
[Image: 69058351122571262507.jpg]
This British Standard provides recommendations for methods for the fatigue design and assessment of parts of steel structures which are subject to repeated fluctuations of stress. It is concerned with wrought structural steel with specified minimum yield strength of up to 700 N/mm2 operating in the sub-creep regime.
This standard is applicable to the following:
a) parent material remote from joints;
b) welded joints (in air or sea water) in such material;
c) bolted or rivetted joints in such material;
d) shear connectors between concrete slabs and steel girders acting compositely in flexure.
Guidance on general fatigue design philosophy is given in Annex A, which also contains a brief description of the method of using this standard.
This standard takes no account of the possible onset of unstable fracture from a fatigue crack.
This standard does not apply to the following:
orthotropic decks;
wire ropes;
bonded connections;
steel reinforcement in concrete;
out of plane joints between hot rolled rectangular or square hollow sections;
pressure vessels;
castings;
peening.
  • Grunf, kowheng, dbsimon29, salahcivil, toa011, Dell_Brett, gacella, jcbv, dinu69in, usman, blaze, oanm2000, zrilek, peixoto, hodzicemir
10-07-2012, 04:38 AM
New links:
  • malc, jcbv, Dell_Brett, Jackass, slowet, zrilek, chenamoy, Trishu999, cowboy, hodzicemir
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
11-18-2013, 06:46 AM
new links:
password:
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  • lisine, Matt89
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
03-05-2015, 04:08 AM
concrete solution advocate
[-] The following 6 users Like concreteok's post:6 users Like concreteok's post
  • hodzicemir, PinkPant, oanm2000, amindoxiti, Dell_Brett, Mohammad6299
03-14-2015, 03:11 AM
BS 7608:2014 Guide to fatigue design and assessment of steel products
Author: Technical Committee WEE/37 | Size: 1,77 MB | Format: PDF | Quality: Original preprint | Publisher: BSI | Year: 2014 | pages: 140 | ISBN: 9780580540905
[Image: 96210147483822073409.jpg]
This British Standard gives methods for assessing the fatigue life of parts of steel products that are subject to repeated fluctuations of stress. It is applicable to all areas of industrial application that are not covered by other British Standards containing fatigue assessment rules.
  • Dell_Brett, concreteok, Mohammad6299, malc, amindoxiti, jcbv, f_slikken, zrilek, bridgeengineer, PinkPant, oanm2000, Priit, PanosP, kasiphonk, avge, subin91
 Dobblo
South Africa
User ID: 44024
Threads: 6
Likes: 319 in 31 posts
Given Likes: 43
12-15-2015, 09:46 AM
[-] The following 9 users Like Dobblo's post:9 users Like Dobblo's post
  • f_slikken, bridgeengineer, PinkPant, kasiphonk, slowet, jcbv, Dell_Brett, Jackass, oanm2000
  [CivilEA Exclusive] BS EN 1993-1-8 Eurocode 3. Design of steel structures - Joints poolmand 0 2,826 02-04-2025, 12:42 PM
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,175 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,508 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,043 06-07-2023, 05:10 AM
Last Post: ersin
  BS 6089:Guide to assessment of concrete strength in existing structures ir_71 8 5,779 02-14-2022, 05:40 AM
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,069 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,291 07-31-2021, 08:00 PM
Last Post: monter
