Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 4449:1997+A1 Specification for Carbon steel bars for the reinforcement of concrete
01-29-2011, 05:05 AM
Author: Technical Committee ISE/9 | Size: 0.3 MB | Format: PDF | Publisher: BSI | Year: 2001 | pages: 24 | ISBN: 0580273466
[Image: 83718320962317905650.jpg]
This British Standard specifies requirements for weldable steel bars for reinforcement of concrete. It covers plain round steel bars in grade 250, and deformed (type 1 and type 2) high yield steel bars in grade 460, the latter in two ductility categories, 460A and 460B. The weldability requirements for both grades of steel are specified in terms of the carbon equivalent value. A testing facility for material covered by a third party product certification scheme, and a testing facility for material not covered by such a scheme, are provided. Steel bars for use as lifting hooks are not included in this British Standard. Steel bars produced by re-rolling finished products, or by rolling material of which the metallurgical history is not fully documented or not known, are not covered by this British Standard.
NOTE 1 Flash welds in lengths of bar are permissible. However, for some purposes, purchasers may specifically require bars without flash welds. For this reason, the manufacturer should enquire whether flash welds are acceptable for the purposes of the purchaser at the time of enquiry and/or order (see Annex A).
NOTE 2 All steels conforming to this British Standard are of weldable quality. Appropriate welding procedures and consumables, to each particular grade and quality, should be used (see BS 7123).
  • kowheng, ssobhan, usman, vvvv, Dell_Brett, blaze, oanm2000, cordoba123, chenamoy, zrilek, salahcivil, toa011, Grunf, roaming79, hmwere, peixoto
02-22-2011, 07:31 PM
BS 4449:2005 +A2:2009 Steel for the reinforcement of concrete — Weldable reinforcing steel — Bar, coil and decoiled product — Specification
Author: Technical Committee ISE/9 | Size: 0.65 MB | Format: PDF | Publisher: BSI | Year: 2009 | pages: 34 | ISBN: 9780580645853
[Image: 06251745290814640473.jpg]
This British Standard specifies requirements for ribbed weldable reinforcing steel used for the reinforcement of concrete structures. The standard covers steel delivered in the form of bars, coils and decoiled products. The standard contains provisions for three steel grades, all of 500 MPa characteristic yield strength, but with different ductility characteristics. The three grades are B500A, B500B and B500C. The weldability requirements for all grades of steel are specified in terms of the chemical composition, and in particular the carbon equivalent value. Steel bars produced by re-rolling finished products, or by rolling material of which the metallurgical history is not fully documented or not known, are not covered by this British Standard.
NOTE Flash welds in lengths of bar are permissible under this standard, provided all the mechanical requirements are met. However, for some purposes, purchasers might specifically require bars without flash welds, and if so this ought to be stated at the time of enquiry and/or order.
  • Dell_Brett, toa011, kowheng, Grunf, oanm2000, roaming79, hmwere, zrilek
10-08-2012, 04:05 AM
New links:
  • Jackass, malc, mahyarov, Dell_Brett, zrilek, lisine, peixoto, chenamoy
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
05-15-2014, 07:52 AM
links dead; reposted
password:
[-] The following 4 users Like andersen3's post:4 users Like andersen3's post
  • PinkPant, Dell_Brett, zrilek, Mohammad6299
  BS 8666 - Steel Reinforcement for Concrete (specifications) Nilupa 4 4,866 12-16-2021, 03:49 PM
Last Post: aslam
  BS 7973 Spacers and chairs for steel reinforcement and their specification ir_71 3 3,783 11-27-2019, 06:39 AM
  BS EN 206:2013 Concrete — Specification, performance, production and conformity ir_71 1 2,464 11-11-2019, 12:33 AM
Last Post: concreteok
  BS 4449:2005+A3:2016 yakwetu 0 1,885 05-13-2016, 10:18 PM
Last Post: yakwetu
  BS 4449:2005+A2:2009 Steel for the reinforcement of concrete — Weldable reinfor... portal61 4 4,087 09-16-2014, 12:20 PM
  BS 4515-1:2009 Specification for welding of steel pipelines on land and offshore mybest 2 3,014 07-17-2014, 02:11 AM
Last Post: legend2611
  BS EN 10060:2003 Hot rolled round steel bars for general purposes - Dimensions and to ir_71 2 2,821 05-15-2014, 08:18 AM
