Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 10349:2009 Steel castings - Austenitic manganese steel castings
01-09-2011, 06:27 PM (This post was last modified: 01-10-2011, 05:35 AM by ir_71.)
Author: ECISS/TC 31 | Size: 0.45 MB | Format: PDF | Publisher: CEN | Year: 2009 | pages: 10 | ISBN: 9780580590252
[Image: 98922739286613899099.jpg]
This European Standard specifies austenitic manganese cast steels for wear-resistant service. The grades
covered by this European Standard will experience maximum service life in applications where the surface of
the casting is subject to impact.
This European Standard retains the same format for clauses as EN 1559-1 and EN 1559-2. It shall be used in
conjunction with these standards. Where no text is given under a clause heading, the corresponding clause
of EN 1559-1 or EN 1559-2 applies.
The structure of this standard is as follows:
a) clauses and subclauses preceded by
  • usman, Grunf, oanm2000, toa011, roaming79
  EN 10346:2009 Continuously hot-dip coated steel flat products Grunf 6 6,713 03-12-2022, 01:55 PM
Last Post: Kurucz
  EN 10028:2009 Flat Products Made of Steel for Pressure Purposes Standard series ir_71 1 2,291 03-12-2014, 05:50 PM
  EN 15512:2009 Steel static storage systems — Adjustable pallet racking systems - Prin ir_71 0 2,342 01-01-2011, 08:22 PM
  EN 10283:2010 Corrosion resistant steel castings ir_71 0 1,836 10-24-2010, 02:51 PM
  EN 10340:2008 Steel castings for structural uses ir_71 0 1,795 10-24-2010, 02:44 PM
