Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 10283:2010 Corrosion resistant steel castings
10-24-2010, 02:51 PM
This European Standard applies to corrosion resistant steel castings for general purposes.
This standard relates to castings manufactured from martensitic, austenitic, fully austenitic and austenitic-ferritic steel grades characterised by their chemical composition (see Table 1) and mechanical properties (see Table 2).
In cases where castings are joined by welding by the founder, this European Standard applies.
In cases where castings are welded:
- to wrought products (plates, tubes, forgings);
- or by non founders;
this European Standard does not apply.
:JC_cheers:
  • lamkin, Dell_Brett, kowheng, toa011, roaming79
  EN 10349:2009 Steel castings - Austenitic manganese steel castings ir_71 0 1,987 01-09-2011, 06:27 PM
  EN 10340:2008 Steel castings for structural uses ir_71 0 1,797 10-24-2010, 02:44 PM
