Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS ISO 14347:2008 Fatigue - Design procedure for welded hollow-section joints - Recom
12-12-2010, 11:33 AM (This post was last modified: 06-17-2015, 11:31 AM by 3fan.)
BS ISO 14347:2008 Fatigue - Design procedure for welded hollow-section joints - Recommendations
Author: International Institute of Welding, Commission XV | Size: 2.4 MB | Format: PDF | Publisher: ISO | Year: 2008 | pages: 76 | ISBN: 978 0 580 53490 4
[Image: 54979609098621556697.jpg]
1.1 General
This International Standard gives recommendations for the design and analysis of unstiffened, welded, nodal
joints in braced structures composed of hollow sections of circular or square shape (with or without
rectangular chord) under fatigue loading.
This International Standard applies to structures:
a) fulfilling quality requirements for hollow sections (see Annex A);
b) complying with recommended weld details (see Annex B);
c) employing permitted steel grades (see 1.2);
d) having hollow section joints (see 1.3);
e) having either
1) square or rectangular hollow sections with a thickness between 4 mm and 16 mm, or
2) circular hollow sections with a thickness between 4 mm and 50 mm;
f) having as stress range the range of “hot-spot” stress;
g) having identical brace (branch) members.
1.2 Materials
This International Standard applies to both hot-finished and cold-formed steel structural hollow sections,
complying with the applicable national manufacturing specification, that fulfil specified quality requirements
(see Annex A).
1.3 Types of joints
This International Standard applies to joints consisting of circular hollow sections (CHS) or rectangular hollow
sections (RHS) as used in uniplanar or multiplanar trusses or girders, such as T-, Y-, X-, K-, XX-, and
KK-joints (see Figure 1 and Figure 2).
  • blaze, kowheng, Dell_Brett, jcbv, toa011, roaming79, Grunf, usman, zrilek, sackk, vvvv
03-17-2012, 04:48 PM (This post was last modified: 06-17-2015, 11:32 AM by 3fan.)
New links:
  • Dell_Brett, foxxx2010, sodapas, malc, zrilek, Jackass, peixoto, vpmohammed
06-18-2015, 04:15 AM
  • zrilek, PinkPant, vvvv, atram, Dell_Brett, lisine, 3fan, f_slikken, ssobhan, amindoxiti, subin91, PanosP, slowet, caifan, malc, bridgeengineer
  [CivilEA Exclusive] BS EN 1993-1-8 Eurocode 3. Design of steel structures - Joints poolmand 0 2,853 02-04-2025, 12:42 PM
  BS 6093 - Design of Joints dinu69in 3 3,476 11-28-2019, 10:54 AM
  BS EN 10219:2006 Cold formed welded structural hollow sections of non-alloy and fine ir_71 4 4,224 06-03-2019, 09:56 AM
Last Post: concreteok
  BS ISO 12108:2002 Metallic materials. Fatigue testing. Fatigue crack growth method ir_71 2 2,702 12-24-2014, 11:25 AM
Last Post: sssiin
  BS EN ISO 10321:2008 Geosynthetics. Tensile test for joints/seams by wide-width strip mybest 2 2,208 02-22-2013, 08:08 AM
Last Post: arshiakh
  BS EN ISO 5817:2007 Welding. Fusion-welded joints in steel, nickel, titanium and thei mybest 1 3,079 02-21-2013, 01:54 PM
Last Post: arshiakh
  BS 6093:2006 Design of joints and jointing in building construction. Guide ir_71 1 2,501 09-21-2012, 05:35 PM
