Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 1881 Testing Concrete
11-29-2010, 05:30 AM
Author: BSI | Size: 17.8 MB | Format: PDF | Publisher: BSI
Contents of the package:
BS 1881-131:1998
Testing concrete. Methods for testing cement in a reference concrete
BS 1881-128:1997
Testing concrete. Methods for analysis of fresh concrete
BS 1881-130:1996
Testing concrete. Method for temperature-matched curing of concrete specimens
BS 1881-208:1996
Testing concrete. Recommendations for the determination of the initial surface absorption of concrete
BS 1881-103:1993
Testing concrete. Method for determination of compacting factor
BS 1881-129:1992
Testing concrete. Method for determination of density of partially compacted semi-dry fresh concrete
BS 1881-207:1992
Testing concrete. Recommendations for the assessment of concrete strength by near-to-surface tests
BS 1881-127:1990
Testing concrete. Method of verifying the performance of a concrete cube compression machine using the comparative cube test
BS 1881-209:1990
Testing concrete. Recommendations for the measurement of dynamic modulus of elasticity
BS 1881-124:1988
Testing concrete. Methods for analysis of hardened concrete
BS 1881-204:1988
Testing concrete. Recommendations on the use of electromagnetic covermeters
BS 1881-205:1986
Testing concrete. Recommendations for radiography of concrete
BS 1881-206:1986
Testing concrete. Recommendations for determination of strain in concrete
BS 1881-125:1986
Testing concrete. Methods for mixing and sampling fresh concrete in the laboratory
BS 1881-203:1986
Testing concrete. Recommendations for measurement of velocity of ultrasonic pulses in concrete
BS 1881-201:1986
Testing concrete. Guide to the use of non-destructive methods of test for hardened concrete
BS 1881-202:1986
Testing concrete. Recommendations for surface hardness testing by rebound hammer
BS 1881-115:1986
Testing concrete. Specification for compression testing machines for concrete
BS 1881-105:1984
Testing concrete. Method for determination of flow
BS 1881-113:1983
Testing concrete. Method for making and curing no-fines test cubes
BS 1881-109:1983
Testing concrete. Method for making test beams from fresh concrete
BS 1881-111:1983
Testing concrete. Method of normal curing of test specimens (20°C method)
BS 1881-112:1983
Testing concrete. Methods of accelerated curing of test cubes
BS 1881-108:1983
Testing concrete. Method for making test cubes from fresh concrete
BS 1881-110:1983
Testing concrete. Method for making test cylinders from fresh concrete
BS 1881-101:1983
Testing concrete. Method of sampling fresh concrete on site
BS 1881-106:1983
Testing concrete. Methods for determination of air content of fresh concrete
BS 1881-107:1983
Testing concrete. Method for determination of density of compacted fresh concrete
BS 1881-102:1983
Testing concrete. Method for determination of slump
BS 1881-104:1983
Testing concrete. Method for determination of Vebe time
BS 1881-119:1983
Testing concrete. Method for determination of compressive strength using portions of beams broken in flexure (equivalent cube method)
BS 1881-118:1983
Testing concrete. Method for determination of flexural strength
BS 1881-117:1983
Testing concrete. Method for determination of tensile splitting strength
BS 1881-114:1983
Testing concrete. Methods for determination of density of hardened concrete
BS 1881-116:1983
Testing concrete. Method for determination of compressive strength of concrete cubes
BS 1881-122:1983
Testing concrete. Method for determination of water absorption
BS 1881-120:1983
Testing concrete. Method for determination of the compressive strength of concrete cores
BS 1881-121:1983
Testing concrete. Method for determination of static modulus of elasticity in compression
BS 1881-5:1970
Testing concrete. Methods of testing hardened concrete for other than strength
Total 40 standards.
I apologize to all in advance if I missed a document.
[-] The following 19 users Like ir_71's post:19 users Like ir_71's post
  • kowheng, usman, blaze, sangxd80, Grunf, zrilek, Dell_Brett, giga, roaming79, toa011, super_engineer, wanazri, buraz, parwez007, mz55, nigema, huan_maivn, 3fan, Nilupa
 Jackass
Semi Senior Member
Banned
Bolivia
User ID: 29460
Threads: 33
Likes: 1,138 in 115 posts
Given Likes: 7399
06-17-2012, 09:38 PM
Hi
I find same link in 4shared
[-] The following 16 users Like Jackass's post:16 users Like Jackass's post
  • ssobhan, 3fan, utan, techno, sathish, malc, zrilek, vvvv, isurya, st77bel, mahyarov, miquan, shadabg, pram, osw90, harsono
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
09-19-2012, 03:13 PM (This post was last modified: 09-19-2012, 03:56 PM by miquan.)
Dear all,
Link of ir_71 is dead.
In Jackass link, some codes are lost.
Miquan
[-] The following 6 users Like miquan's post:6 users Like miquan's post
  • Grunf, Jackass, malc, Trishu999, lisine, osw90
  BS 1881-204:1988 Hengki 2 3,459 06-28-2011, 01:13 PM
Last Post: meekaaku
