Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive I need guide on Progressive Collapse
 capaturtle
User ID: 27399
Threads: 2
Likes: 0 in 0 posts
Given Likes: 0
08-23-2010, 07:28 AM
Hi, Im new here. I need help from people here about progressive collapse. I know there is GSA Progressive collapse but I need guide to really understand this GSA code and how to produce analysis using software such as STAADPro. Thanks in advance,,
 killerbee
User ID: 22528
Threads: 8
Likes: 215 in 19 posts
Given Likes: 158
09-29-2010, 07:44 AM
I need it too. I am searching at the moment. I will share once i find it.
 killerbee
User ID: 22528
Threads: 8
Given Likes: 158
11-12-2010, 09:35 AM (This post was last modified: 11-12-2010, 09:38 AM by BennyP.)
I found this relevant thread
[-] The following 4 users Like killerbee's post:4 users Like killerbee's post
  • zrilek, ravisbassi, chigozie, jcbv
 NAUTILUS87
Senior Member
Banned
User ID: 8709
Threads: 107
Likes: 1,442 in 136 posts
Given Likes: 361
11-14-2010, 10:14 AM
Guys Staad Pro is not a software you should be looking for if you want to know about progressive collapse analysis . It is not that high end , you will be needing a software/program code that takes discretion into account . There are only three ways of doing it .You can use any one of these
1) Applied element method
2) Discrete element method
3) Finite-Discrete Element Method
AEM has its own programmable code . I used it for my own thesis l, DEM is used widely for soil-structure and many geotechnical analysis, and FDEM it is similiar to dem and fem both but very good .
All the above mentioned methods are research oriented you need to work for nearly 6-8 month just only to understand them. As far as Progressive Collapse analysis is concerned , you need to develop a nonlinear model or use one use it in fem code and the Force-displacement curve for every member of the structure . Now you have to use the FEMA code to find see the plastic hinges and points .
I would recommend SAP2000 because i used the software for this purpose .
I have given a very very concise methodology for progressive collapse analysis .
You have also use ansys or abaqus . They are meant for such high end purpose only .
[-] The following 4 users Like NAUTILUS87's post:4 users Like NAUTILUS87's post
  • Dell_Brett, chigozie, killerbee, david-smith
  [REQUEST] Progressive collapse analysis of high rise building hmwere 2 2,254 02-08-2013, 08:39 AM
  Investigation of progressive collapse resistance and inelastic response of Earthquake NAUTILUS87 2 2,485 02-07-2013, 02:27 PM
Last Post: devilmaycry
  [REQUEST] Alternate Path method in progressive collapse analysis: Variation of dynamic and non- david-smith 1 1,840 06-03-2012, 05:53 PM
Last Post: hich
  [REQUEST] Prevention of Progressive Collapse in Multistory Concrete Buildings budis 0 1,623 01-07-2011, 10:39 AM
Last Post: budis
  Progressive Collapse of Structures cnman 0 1,760 09-16-2009, 08:33 AM
Last Post: cnman
