Civil Engineering Association eBooks Codes, Manual & Handbook Eurocode (EC) EN 50341-1:2001 Overhead electrical lines exceeding AC 45 kV
 Songoku
Azores
User ID: 2786
Threads: 29
Likes: 76 in 19 posts
Given Likes: 182
06-15-2010, 08:52 PM (This post was last modified: 05-10-2012, 10:39 PM by usman.)
EN50341
[-] The following 2 users Like Songoku's post:2 users Like Songoku's post
  • z_q_h, PinkPant
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
05-10-2012, 11:36 AM
DIRECT LINKS thumbup
[Image: comments.png]
National Normative Aspects for Austria
[-] The following 6 users Like 3fan's post:6 users Like 3fan's post
  • st77bel, Jackass, louislouis, blaze, PinkPant, ranasanga
05-10-2012, 07:45 PM
EN 50341-1:2001 Overhead electrical lines exceeding AC 45 kV -- Part 1: General requirements - Common specifications
Author: Technical Committee CENELEC TC 11 | Size: 0.9 MB | Format: PDF | Quality: Original preprint | Publisher: CEN/CENELEC | Year: 2001 | pages: 230
[Image: 60224805285865825838.jpg]
This standard applies to overhead electric lines with rated voltages exceeding 45 kV AC and with rated frequencies below 100 Hz.
This standard specifies the general requirements that shall be met for the design and construction of new overhead lines to ensure that the line is suitable for its purpose with regard to safety of persons, maintenance, operation and environmental considerations.
NOTE 1 The extent of the application of this standard by each country in respect of existing overhead lines is subject to the requirements of the National Normative Aspects (NNA) applicable to that country.
NOTE 2 Design and construction of overhead lines with insulated conductors, where internal and external clearances can be smaller than specified in the standard are not included. All other requirements of the standard may be applied to overhead lines with insulated conductors. When necessary, requirements for clearances can be given in the NNAs.
NOTE 3 This part of the standard is applicable for optical Ground Wires (OPGWs) and optical Conductors (OPCONs). However the standard is not applicable to telecommunication systems which are used on overhead transmission lines either attached to the transmission line conductor/earth wire system (for example wraparound,...) or as separate cables supported by the transmission supports for example All Dielectric Self Supporting (ADSS) or for telecommunication equipment mounted on individual transmission line structures. When necessary, requirements can be given in the NNAs.
This standard does not apply to :
- overhead electric lines inside closed electrical areas as defined in HD 637;
- catenary systems of electrified railways.
  • 3fan, jcbv, SCREAM7890, malc, Jackass, kowheng, peixoto, louislouis, zrilek, Dell_Brett, warbeast, nhim4mat2006, PinkPant
12-06-2012, 07:58 PM
New links:
  • Dell_Brett, lisine, zrilek, nhim4mat2006, PinkPant, ranasanga
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
11-25-2013, 10:50 AM
all links dead; new links:
password:
  • Dell_Brett, Rapaig, jcbv
 andersen3
User ID: 464
Threads: 54
Given Likes: 1243
06-13-2018, 07:45 AM
new link
password
[-] The following 7 users Like andersen3's post:7 users Like andersen3's post
  • PinkPant, oanm2000, karthikeyans3d, Dell_Brett, ashcivilea, monter, nhim4mat2006
  EN 50341-3-17 - National Normative Aspects for Portugal Songoku 1 2,290 12-07-2012, 12:00 AM
Last Post: Songoku
