Civil Engineering Association eBooks Structural Books Concrete Design of Concrete Structures for Retaining Aqueous Liquids by R. Cheng
 titko
User ID: 10598
Threads: 17
Likes: 522 in 69 posts
Given Likes: 241
06-08-2010, 09:32 AM (This post was last modified: 08-16-2010, 02:29 AM by concreteok.)
[Image: 95239764691605435655.jpg]
Book Description:
Design Table to BS 8007
# Hardcover: 57 pages
# Publisher: Thomas Telford Ltd (17 April 1996)
# Language English
# ISBN-10: 0727725173
# ISBN-13: 978-0727725172
# Product Dimensions: 29 x 20.4 x 0.8 cm
Product Description
Concrete expands and then contracts because of the increase in temperature during hydration of cement and subsequent fall in temperature. In continuous structures, if this movement is restrained, tensile stresses will develop which can cause cracks to form. Although it is accepted that there will be cracks in reinforced concrete structures, the degree and magnitude of cracking should be controlled. In the design of liquid retaining structures, it is essential to restrict the width of cracks in structures. The maximum design surface crack widths (w) in BS8007 for direct tension and flexure or restrained temperature and moisture effects are as follows: w = 0.2 mm for severe or very severe exposure; and, w = 0.1 mm for critical aesthetic appearance.The design calculations of both the serviceability limit state of cracking due to thermal and moisture effects and flexural can be tedious and time consuming. In the preliminary design stage, the design tables in this document will assist and 'short-cut' the design process and therefore save valuable time. "Design tables to BS8007" has been divided into two parts. Part 1 provides calculations of minimum reinforcement, crack spacing, and crack widths in relation to temperature and moisture effects. It summarises the design formulae and tables A1 to A6 provide calculated reinforcements required for control of thermal and shrinkage cracking. Part 2 provides calculations of crack widths in mature concrete under structural loading. It summarises the design formulae and tables B1 to B36 tabulate the service and ultimate flexural capacity of a range of slab thickness and reinforcement arrangements under differing conditions of crack width limitation, concrete strength and cover.
link to page 19 (pls use links from the replies for the book)
Edit reason: Added info, cover image edited using CivilEA's image host. (G)
[-] The following 22 users Like titko's post:22 users Like titko's post
  • mig21, kowheng, mgdario, Dell_Brett, rendel_©, orambo, tamboon, cristi, mecheil.edwar, igor1234, oanm2000, bhawk0, ravisbassi, Mohoh77, triance, axee1980, ali akbar, pm81, Nilupa, er.shyams, yutt, bigone
 yakwetu
User ID: 1947
Threads: 57
Likes: 1,240 in 130 posts
Given Likes: 154
06-08-2010, 11:56 AM
[-] The following 21 users Like yakwetu's post:21 users Like yakwetu's post
  • salahcivil, lamkin, chenamoy, toa011, batata666, Dell_Brett, levanduy, redtony, ruaumoko, zrilek, civilgr, mgdario, hadeest, sodapas, saed, kaungthant, DamaD, super_engineer, oanm2000, Jackass, bigone
06-08-2010, 01:16 PM (This post was last modified: 11-07-2010, 06:05 PM by Grunf.)
Mirror links:
zip 61.86 MB
If you like this book, buy it! Support the author(s) of the book!
[-] The following 24 users Like Grunf's post:24 users Like Grunf's post
  • jcbv, Dell_Brett, levanduy, zrilek, ireland, civilteam, DamaD, oanm2000, vvvv, ladjin, we_mbm, rendel_©, shaqee, kaungthant, itcssaec, blaze, vardan, kg85arun, axee1980, lisine, Nilupa, user108, Alexander, bigone
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
11-07-2010, 05:58 PM
Mirror
19.4MB single PDF
[-] The following 12 users Like usman's post:12 users Like usman's post
  • Dell_Brett, oanm2000, shanta, ravisbassi, robertsas, triance, we_mbm, chicosi, Nilupa, Umer.Aleem, bhawk0, bigone
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
06-08-2012, 02:27 PM (This post was last modified: 06-08-2012, 02:28 PM by junaid.)
Other Link:
[-] The following 25 users Like junaid's post:25 users Like junaid's post
  • odiclas, seriousboy, zrilek, Quantumm, marion33, malc, Dell_Brett, gulilero, kowheng, subin91, jacs127, Jackass, cace-01, knrsa, oanm2000, DamaD, we_mbm, draluka, GMianG, nickycruz, er.shyams, Trishu999, techno, bigone, hmwere
 scorpion07
Albania
User ID: 550
Threads: 3
Likes: 1,366 in 104 posts
Given Likes: 277
01-29-2016, 11:29 PM
New Links
[-] The following 16 users Like scorpion07's post:16 users Like scorpion07's post
  • Dell_Brett, sodapas, emmi, ykhackhack, blaze, f_slikken, PinkPant, Andrew seah, oanm2000, dinu69in, axcel, milova, mgdario, bridgeengineer, narendra, moh_towhid
  Design Aids for Eurocode 2: Design of concrete structures Grunf 2 3,855 04-13-2022, 09:44 AM
Last Post: melekeen
  design of prestressed concrete structures - T. Y. Lin lamkin 7 6,153 12-29-2020, 03:28 PM
Last Post: aslam
  How to Design Concrete Structures using Eurocode 2 gboyega 9 7,429 01-29-2020, 05:16 AM
Last Post: cargadory2k
  Concrete Durability: A Practical Guide to the Design of Durable Concrete Structures carolinandra 1 2,041 05-01-2019, 03:06 AM
  Design of Reinforced Concrete Structures RyanRS 0 2,294 06-02-2017, 04:00 PM
Last Post: RyanRS
  Design of Liquid Retaining Concrete Structures zbizafar 5 7,105 12-11-2016, 09:14 PM
Last Post: Dell_Brett
  FIB 38: Fire design of concrete structures - materials, structures and modelling Mohammad6299 2 2,153 03-29-2016, 08:27 AM
Last Post: yakwetu
