Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Calculation Notes & Analysis Files Matlab code: P-M-M, P-M, Mx-My interaction curves for short columns of any shape
 spymaster007
Junior Member
User ID: 27116
Threads: 3
Likes: 64 in 10 posts
Given Likes: 6
09-24-2012, 09:08 AM
MATLAB code: PMM,PM,MM interaction curves for short columns of practically any shape
[Image: 56594058943971094035.jpeg]
[Image: 54810329517689080153.jpeg]
[Image: 43684712278123502240.jpeg]
[Image: 25058282621862967855.jpeg]
[Image: 11880012113107766134.jpeg]
The Matlab code for rectangular column interaction curve I posted last week is actually incorrect. The new one I post now can create the P-M-M, M-M, P-M interaction curves for short columns of practically any arbitrary shapes including openings. It has been extensively checked with spColumn v4.81 lastest version that shows excellent agreement.
4 main srcipt m files are included:
- RcolPMMall_1.m ---> rectangular column
- LcolPMMall_1.m ---> L-shaped column
- CcolPMMall_1.m ---> C-shaped column
- CcolPMMall_1w1O ---> C-shaped column with opening.
For typical regular shapes (rectangle, T, L, C, I, Z, Cross, regular polygons), the global coordinates (Xo,Yo,Xbo,Xbo) of the section & reinf bars can be readily built into the program. For an arbitray shape, they need to be specified.
Other files are supporting functions:
- polygeom.m: calculates area & centriodal coordinates of a polygon (this one I gleaned from the web; the rest are my own's)
- fcutpolygon1.m: cuts a polygon into 2 parts, retains & renumbers one of them for use (this is an essential part used to isolate the concrete compression block) + other minor .m files.
The program produces 4 graphs:
- geometry & reinf patern
- 3D P-M-M surface plot
- 2D Mx-My plot for a specified level of axial force P (that you can change)
- 2D P-M plot for a specified angle (GAMMA)of direction of biaxial bending moment
15 levels of P are used (changeable) ---> for some irregular shapes, the surface plot might look jagged in some places where the contours twist a lot.
Download link for Matlab m files below
Note: for correct results, corner points (Xo,Yo) of arbitary shapes are entered CLOCKWISE for main geometry & COUNTERCLOCKWISE for openings.
global coordinates
[Image: tips.png]
unzip into 1 folder, make it your current working Matlab file & run one of the main m files.
[-] The following 17 users Like spymaster007's post:17 users Like spymaster007's post
  â€¢ devilmaycry, avscorreia, kowheng, Dell_Brett, utan, malc, jcbv, blaze, NAUTILUS87, oanm2000, ibg0203, fer962933, melekeen, ykhackhack, mantre, AloneGalaxy, BlackHawk9
Threads: 49
11-23-2012, 05:53 AM
link here
[-] The following 11 users Like andersen3's post:11 users Like andersen3's post
  â€¢ Dell_Brett, blaze, Jackass, oanm2000, fer962933, melekeen, mgdario, simanta, cabpcabp, BlackHawk9, konstobo
  [Matlab] Partition Matrix code elbarto_87 3 10,288 10-07-2012, 11:00 AM
Last Post: elbarto_87
  Matlab Code for 4 nods N elements alexjakson 0 5,916 12-17-2010, 05:32 AM
Last Post: alexjakson
